Tom's Hardware > Forum > Graphic & Displays > ATI > 4870HD Major Problem
Forum Graphic & Displays : ATI - 4870HD Major Problem
Hi, Only recently i have been having some major pc problems, i think the problem is my 4870. When ever i start a game i only play it for about 10 minutes befor my screen freezes, i end up having to restart every time. My card idles at 70deg which is the average for that card, i have tried turning the fan up with rivertuner to get the card down to about 50, but that doesnt seem to be doing very much.
http://img262.imageshack.us/my.php [...] 589xn1.jpg
thats what it looks like, just frozen like that
thanks in advanced for any help i can get :wahoo:
Windows Vista 64Bit
Q6600
Gigabyte GA-EP45-DS4P
2x 2GB Patriot DDR2800
Message edited by sylvaner on 12-06-2008 at 10:47:23 AM
Sponsored Links
Don't the most recent drivers allow fan adjustments in the CCC?
Reply to cheesevillage
Yes it does, however Rivertuner allows you to control the fan speed with out Unlocking your card.
PS my CCC is: 8-11_vista64_dd_ccc_wdm_enu_70230
Reply to sylvaner
I guess the real question is what temps you are hitting under load.
As per "unlocking" - I thought controlling the fan with CCC with totally legit.
Hey, i just played Red Alert 3 on max and the max my card got to without rivertuner changing the fan speed was 73 degreese
Would heat still be the issue, my computer only crashes whilst playing games, would three degreese realy make my computer so unstable?
thanks =)
Reply to sylvaner
Before the driver that let you control the fan I did the fan hack trick. I set it to 37% and the card never got to 58c. ( HIS )
Try popping the side off your case. You may not be getting enough cool outside air.
And since ATI provides the fan adjustment with the newer drivers, why don't you disable rivatuner ? I wouldn't worry about the "unlocking" mumbo jumbo at this point.
You may also try and remove the heat sink and try and put some new smooch on it and re-seat it.
You might want to try and use the CCC unlock to UNDER CLOCK your card. see what happens.
Message edited by swifty_morgan on 12-06-2008 at 12:31:06 PM
Reply to swifty_morgan
try teh latest drivers. 8.12 arent they? maybe a beta 8.13?
Reply to V3NOM
Like someone mentioned, the airflow inside your case is very important. If you have a small case and it gets really hot inside, turning up your fan to 100% won't really matter since you're still blowing hot hair - only faster. So yeah, open up your case and blow a normal fan into it if need be.
Another issue could be your PSU. How many watts does it have? Your freezing could result if you don't have enough wattage since playing games will increase your card's load.
Reply to kingtz
8.11 are the newest official. 8.12 will be out in a week or so. (And 8.13 is 9.1 since it is year.month).
------------------------------ New Build : Intel Core i5 750 > Gigabyte GA-P55-UD4P > 2x2GB GSkill 1600MHz CL7 1.65V > Samsung Spinpoint F3 1TB >
Antec 300 Illusion > Asus 4850 512MB w/AM Cooler > Corsair 650HX > CM Hyper 212 Plus > Other: PII 940/Gigabyte 790GX/4850 1G
Reply to EXT64
Hi all and thanks for the help.
Currently my PSU is the coolermaster 500W with the special 8 pin connecters for the new motherboard, i have a 650W Coolermaster lying around is 500W isnt enough for my current setup.
My case is the P182 by Antec, i think the airflow throughout the case is good and my hard drives are all in the botom bay to keep heat away from all my motherboard, graphics, cpu ect.
another thought would be... is my cpu overheating? how hot should Q6600's get under load? mine stays at about 50 deg, is the stock fan good enough?
thanks everybody for your help again, i cant wait until i can get back to Deadspace, Fallout, DoTA and RA3 =) (maybe a little postal 2)
Reply to sylvaner
load temps still depends on your ambient temps. mine never goes past 50c and its running @ 3ghz. fully airconditioned room though and it has a coolermaster hypertx2 (cheap but effective) on top of it. do you have a 3rd party cpu hsf in there?
interestingly enough my 4850 crashes when i have my aircon turned off.
you can also try Antec's Spot Cooler. maybe it'll put off 3c-5c off your gpu temps, just maybe.
theres a PSU guru around here, i forgot he's name, hes quite good with the amps/watts/volts. im guessing he'll pop up sooner or later to help you.
oh yeah i remember his name now, mactronix. find the guy ask him about psu questions. he helped me a lot.
Message edited by wh3resmycar on 12-07-2008 at 08:21:11 AM
Reply to wh3resmycar
haha thanks EXT64! learn something new every day...
Reply to V3NOM
There are 874 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
