This is my first post here and I would like to thank everyone for the help that these forums have given me in the research phase of building a new system. This will be my second time building a computer from scratch, but I was very young the first time I built a system with my dad helping out tremendously.
I would say my budget for this system is around $2,000, give or take. I'd rather it be lower (of course) but over it is also adequate for me at this time. My main reason for building the computer is gaming, but I would like it to be an all-purpose type machine.
This is a run-down of the components I have looked at for this system (a lot of these parts were found using suggestions from this forum).
I am aware there is probably a cheaper option at motherboard, but given my limited knowledge with motherboards and how some have stability issues, I picked out this one. I also would like the option to crossfire in the future.
This case and power supply are probably way overkill, but I like the combo deal newegg has right now and I like to be safe rather than sorry. Suggestions are definitely needed though.
you could definitely save alot of money on a motherboard, so you might wanna reconsider crossfire. 4GB ram is plenty, any more is a waste imo. and the psu is definite overkill, but if you like the bundle that much, there's not much i can say. and for optical drives, just pick up whatever is the cheapest. they're not very different.
Very nice build, but it can be made more cost-effective.
1. The P5E Deluxe is just like the Rampage, with fewer frills, and $69 less.
2. Crossfiring HD 4870 X2 cards is not very cost-effective because games don't scale that well with 4 GPUs.
Total $183+$105 instead of the $295 combo Antec 1200/Antec 1000W + $289 Rampage MB. You lose the ability to add a second HD 4870 X2 but save almost $300.
The Q9550 is the best choice for CPU, no worries. I'd just replace the Freezer with a Xigmatek HDT-S1283.
