My TRUE or new Water Cooling
here is my current setup
antec 1200
i7 920 @ 4.0 Ghz 39C Idle 70 Load
p6t Deluxe
WD Black Cav. 1TB
sapphire 4870x2
6 gig G.Skill 1600
corsair 750watt PSU
im thinking about getting into water cooling for noise purpose. i currently have the TRUE 120 Extreme w/ 2 Scythe "ultra kaze" (push/pull) fans. but its so loud. i think my temps are pretty good on air but it really is loud. tough to watch a movie on when its connected to my 46 inch LED. for around 250$ can i get a good water cooling kit w/ GPU upgrade later for around that price keep the noise down and better my temps?
7 answers Last reply
More about true water cooling
  1. I wouldnt think that would be worth it.... you will not get magnificent temps with water cooling, and as long as your temps dont get to high you could just get some quieter fans.
    BTW, put your overclock in the overclocking club.
  2. cmill, you might look at these:
    Scythe S-Flex SFF21F
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835185006
    Scythe S-Flex SFF21G
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835185065
    I put an "F" on my TRUE. I thought it would be a good compromise between air flow and noise.
    GA-EP45-UD3P | Q9550 OC'd to 3.6 GHz (425 MHz X 8.5) C3 stepping :( |
    1.3625 volts on the core | Antec 900 case | load temps 58 C - 61 C.
  3. When you're just watching movies, back down that oc.
  4. thats a pain in the butt. im looking at getting 2 http://www.newegg.com/Product/Product.aspx?Item=N82E16835185059&cm_re=Scythe-_-35-185-059-_-Product its a 33 dba vs the http://www.newegg.com/Product/Product.aspx?Item=N82E16835185054&cm_re=Scythe-_-35-185-054-_-Product which is 46 dba. how much of a noise diff. is that gonna make? is it going to effect my temps?
  5. There is a pretty significant difference between 33 and 46 Dba, i would suggest something under 30 if you want it real quiet.
    Try these:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835168006
    antec 1200
    p6t Deluxe
    WD Black Cav. 1TB
    sapphire 4870x2
    6 gig G.Skill 1600
    corsair 750watt PSU
    Hey, if you really want into water-cooling go for it. If you the funds and the time for it...by all means. I'd suggest getting a water-block for your GPU first and foremost as thats the fan that usually makes most noise. A block for your CPU will also be necessary. I don't know if you want a chip set block also. A nice, pump, radiator, some nice thermal paste like AS5, tubing, resorvior...etc and your cooling will be better and quiter. However if you want exceptional cooling then get the best radiator you can afford. After all your case is built for this. Just make sure you do it right and know the risks...you dont want leaks anywhere eh...
  7. what do you think about this
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835103063
    90 cfm @ 19dba? is that possible? if so im sold.
Intel Water Cooling Western Digital Overclocking Product
