Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Matherboard driver problem?
Forum Motherboards & Memory : General Motherboard - Matherboard driver problem?
I re-installed my operating system wondows XP professional but now I have in Device Manager driver problems:
other devices
-->multimedia audio controller
-->other pci bridge device
-->sm bus controller
Network card and audio card obviously don't work.
I think it is matherboard driver missing but i haven't a cd and i haven't name of my matherboard.
can someone help me?
Grazie.
Mario
Sponsored Links
If you don't know anything about your system, then it will be difficult to tell you which drivers are required. Can you at least run CPU-Z to identify the motherboard and CPU?
Reply to GhislainG
Sorry, but It's not mine. I'm recovering a system for a person that can't have one. I downloaded CPU-Z, I will post outcomes.
Main usage of this system should be internet browsing and, at the moment, it doesn't work (network card is not identified by OS).
Thanks a lot.
Reply to ioria
You shouldnt be working on anyones computer if you dont know what your doing.
The first thing you do after loading windows is install the motherboards chipset drivers.
------------------------------ P965/Q6700@3.2 8MB HD4850 OC Edition
4GB Corsair XMS 800
Vista64/Win7
Fatality 550w/Antec 300
Reply to zipzoomflyhigh
"I installed MY operating system software on someone else's computer without knowing ANYTHING about the hardware, can anyone help me?" Sure, hang a sign outside your house that says "A COMPUTER TECH DOESN"T LIVE HERE."
Reply to marcellis22
Thank you Ghislaing.
Data using CPU-Z.
CPU
AMD Sempron 2800+
Mainboard.
ASUSTeK Computer INC.
Model --> K8N
Chipset --> NVIDIA nForce3 250
Southbridge --> NVIDIA nForce3 MCP
LPCIO --> ITE IT8712
Is it enough?
I try to search on internet for drivers.
Thanks in advance to everyone can help me to find it.
Mario
Reply to ioria
Download and install the drivers for the Asus K8N. http://www.asus.com/Product.aspx?P_ID=zigzffr75jWJ7j2y
Click the Download tab, select WinXP and download the Version 5.03 chipset drivers from the Others folder. All required drivers (other than Audio) are included in that file.
Reply to GhislainG
SOUNDS LIKE A GATEWAY OR AN EMACHINE COMPUTER POSSIBLY AN OLDER DELL WITH THAT K8N MOBO
AND WITH THOSE PARTICULAR DRIVERS NOT WORKING
IN MY LINE OF WORK (YES IM A TECH )
IN MY LINE OF WORK WHEN THOSE DRIVERS ARE NOT BEING RECOGNIZED AND THOSE SYSTEMS ARE NOT WORKING IT IS MORE THAN LIKELY THAT YOUR MOTHER BOARD "IS" GOING BAD (ITS GOING TO DIE)
THINK OF IT LIKE A CAR MOTOR IT CAN BE BURNING OIL BUT STILL RUN
YOU CAN RUN A V8 MOTOR WITH 4 CYLINDERS BUT ITS GOING TO DIE SOON
Reply to POOCHE001
POOCHE001, why are you so upset?
Reply to GhislainG
Are matherboards are some type of new hybrid between a motherboard and a fatherboard that I am not aware of? Anyone know where can I buy a good one?
Message edited by iu2687 on 03-15-2009 at 05:09:48 AM
Reply to iu2687
There are 1106 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
