Tom's Hardware > Forum > Homebuilt Systems > New System Build > Possible issues with memory voltage? Need an opinion.
Forum Homebuilt Systems : New System Build - Possible issues with memory voltage? Need an opinion.
I'm having issues with a home build, I think i've narrowed the problem down to memory voltage, but just wanted to sanity check what I'm thinking.
I've got an Intel Quad Core @ 2666, an Asus P5K64 WS Mobo, and OCZ Reaper DDR3 RAM @ 1333. I'm seeing general instability in my system in both XP and Vista 64.
When I look at the specs page for my memory it says it requires a voltage of 1.75, but when I run CPU-Z it lists the voltage on each RAM chip @ 1.5 V. I checked my BIOS for a place to set the voltage on the RAM, but I didn't find anywhere to do it. So one question: Is this a likely source of the problem, or am I barking up the wrong tree?
FWIW running AISuite my CPU temp stays around 65 C under load, which I believe is okay....
Sponsored Links
Hmm, now I'm a little worried. I wasn't sure if my CPU temp was too high, just from googling around it looked like it was, so I bought an Arctic Cooling Frezzer 7 Pro, and my temps acutally rose quite a bit. Idle ~ 50C and Prime95 gets to 80 C in a few seconds...
Anyone have any suggestions?
Reply to JoeBroni
First off, I wonder if your BIOS needs a flash to support the newer CPU.
I'm not familiar with that BIOS, but if there is no direct DRAM voltage modifier, look for a setting that adds voltage to the base 1.5V.
Also, what settings does the SPD tab give in CPU-Z?
Use Real Temp to measure your core temps accurately. Those do sound very high.... again could be over voltage caused by older BIOS. Did you clean off the surface of the CPU with a lint free cloth (Coffee filters work well) before installing the new cooler?
Push pins are notoriously subject to failure on coolers. Inspect them very closely to be sure all four are completely seated right.
Reply to Proximon
I've got an ASUS P5K64 WS, flashed to latest-greatest. I dinked around in the BIOS for a bit to no avail, so what I ended up doing was picking up some 1.5 V Corsair DDR3 and putting that in, thinking that if it fixes it I know for sure that was the problem, and then I can either 1) exhaust all possiblities in the BIOS to get my original RAM the voltage it needs and take the new stuff back or 2) keep the new stuff and sell my old ram.
Thanks for the tip on the push pins, turns out the form factor of the Arctic Cooler didn't sit very well in my mobo and only two of the four pins were flush (good old user error). I ended up trying to get that seated for a while before giving up and going back to the stock heat sink/fan combo. Once I got it cleaned up, applied a new layer of thermal pasted, and seated properly my temps are better but still high (using Real Temp). I idle at around 43 C and after a ten minutes of Prime95 I get up around 69-71 on the individual cores. Seems high, but maybe good enough. Just kind of frustrating that I'm reading a lot of posts where people with my proc and stock are running temps much lower than that.
Reply to JoeBroni
This is why we push the Xigmatek along with the retention bracket. Bolt that sucker down and you'll get solid even readings.
You say you applied a "layer." Hopefully not too much. You only need an amount similar to a grain of rice... much more than that will drive those temps up.
Reply to Proximon
Yeah I probably put on too much. Guess it's time to invest in a cooling package that fits on my mobo.
Reply to JoeBroni
There are 1110 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
