I have a 500gb HD and 40 gb Hd (which i use as a portable one). Yesterday, when i connected it to my PC, chkdsk began to run on system startup. As usual, i didnt skip it. As it took more time than usual, i restarted my pc. Now, i cant open that drive(which had 14gb). i cant even check the properties cuz it shows 0 bytes free. Pls HELP!! Can i re-partition the whole drive so that i get this gone 14 gb? If yes, which are the good partition managers?
