Tom's Hardware > Forum > General Networking > General Gateways, Routers and Firewalls > FILE TRANSFER PROBLEM - Cable Modem & 1GB Switch
Forum General Networking : General Gateways, Routers and Firewalls - FILE TRANSFER PROBLEM - Cable Modem & 1GB Switch
We have the following setup:
[SMC Cable Modem/Router - SMC8014]
[Cisco 1Gb/s Switch - SD2008]
Computers/NAS/Etc.
The network does not seem to be operating at 1Gb/s and it seems slow. We are not sure if because the router is not a 1Gb capable, the entire network is running at a slower rate. Does the router need to be 10/100/1000 in order to be running at the maximum level? There are no computers plugged in to the router, only the 1Gb switch. Each computer has a 10/100/1000 network card and the NAS supports it as well.
Is the router slowing everything down? Any input would be greatly appreciated!
P.S.
Would it be better to upgrade to 10Gb/s or Fiber Optic cable to improve the network speed? Want to keep it as cost effective as possible, but also need very fast transfer rates.
Thanks.
Message edited by eProvided_Com on 04-27-2009 at 08:38:37 PM
Sponsored Links
You will achieve gig speed between your nodes in internal network.
For outgoing connections to Internet, you'll only get your ISP speed.
10Gb/s or Fibre connections are used in network backbones or SAN, no need for access level networks. NAS is not a SAN
Reply to JustAGuy51
There are 1297 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ishaan won the Uniformed badge
  • 01:00 nofun won the Uniformed badge
  • 01:00 ElMoIsEviL won the Spy badge
  • 01:00 mparham won the Freshman badge
  • 01:00 ishaan won the Freshman badge
  • 01:00 Mario097 won the Uniformed badge
  • 01:00 timobkg won the Freshman badge
  • 01:00 ethr won the Freshman badge
  • 01:00 amirp won the Freshman badge
  • 01:00 steelmartin won the Freshman badge
