Alright thanks for your help guys, so I took your advice and done a lot of research, but at the moment I have a few questions to ask:
Which ram is better? This one:
http://www.itsdirect.com.au/com_products.php?view=detail&Product_ID=2026&category_id=35&sub_category=15
or the one jstnkim suggested (Patriot Extreme CL4 (LLK))? And seeing that 4gb is kinda alright these days, should I go for 8gb?
I really need help thinking of a good case. It should have e-sata on it and no lights. See through side doesnt matter.
Now for the motherboard is probably the biggest problem of all. Most people say this motherboard is good:
http://www.stonebridgecomputing.com.au/catalog/-p-17774.html
But I thought the x38 chipset was faster than the P45 as I've read somewhere?
Right, just edited and now I have done lots of research and put together this build:
GPU: HIS Hightech HD4870 512MB GDDR5, 750/3600MHz, Full HD 1080p, Dual DL-DVI & TV (HDCP). - HIS-HD4870-E5-V2
http://www.mtechcomputers.com.au/product_info.php?
cPath=0_58_59&products_id=5238&osCsid=9ad905c0baf21d35bef46ff0eeebe268
Motherboard: DFI Lanparty DK P45-T2RS PLUS Intel P45 Chipset Socket 775 Motherboard (update bios) (larger than 5 stock)
RAM: OCZ 4GB (2x 2GB) DDR2 800 Reaper Edition (PC6400) Ram Module Kit (change voltage in bios for this)
CPU: Intel Core 2 Quad Q9550 2.83Ghz
http://www.arc.com.au/?CPUP4775CD2Q95
DVD: 2x Samsung SH-S223F Black SATA 22x DVD/RW Writer (OEM, Nero Included)
http://www.shoppingsquare.com.au/p_5416_Samsung_SHS223F_Retail_SATA_Internal_DL_DVDRW_22X
2 x 29.95 = $60
Case: Love the one that jstnkim suggested but doesnt have esata, help me choose a better one than this? Thermaltake Swing RS 100
http://www.mwave.com.au/newAU/mwaveAU/productdetail.asp?
CartID=mAU@14B3OU436MRVHQP135YHRMBYZFX1B8W6NN6DL4I4KWFW4Z&sku=16010524
$139.00 + $15 shipping
PSU: Corsair HX620W 620W ATX Power Supply, 120mm fan, Dual PCIE VGA Connector
http://www.i-tech.com.au/products/611_Corsair_HX620W_620W_ATX_Power_Supply.aspx
HDD: Samsung/Maxtor(by Seagate) 1TB *Special* Harddisk,SATA2,32MB 7200RPM,NEW! 'HD103UJ' (limited stock)
Card reader: Silverstone FP34B Black 3.5" Card Bay and Front
http://www.stonebridgecomputing.com.au/catalog/-p-5129.html?sCsid=3d66905c5e6ea8d42585de4beb349bc8
All parts come to $AU1826, give or take up to $50 because prices change almost everday. Total shipping costs come to $100.
Some notes, yes I will be using the GPU for the HD stuff. Yes I will get a full HD monitor. and probably taking up maximum of 400gb in 1 year.
PS. Any suggestions on new parts coming out?
PPS. Please tell me your thoughts for the mobo, RAM (should I get 8gb), and GPU.
PPPS. Need some help on a better looking case that has e-sata
