Tom's Hardware > Forum > Homebuilt Systems > New System Build > Case & PSU questions for Atom Mini-ITX System
Forum Homebuilt Systems : New System Build - Case & PSU questions for Atom Mini-ITX System
Hi guys. So I'm at work building a Solaris NAS based on the Intel D945GCLF2 Atom 330 based board. It comes with an integrated Intel Graphics Media Accelerator 950 and an integrated Realtek 10/100/1000 NIC. In addition to the motherboard, I plan to buy 2GB RAM, 2 1TB Samsung Spinpoint SATA 300 disks, a case, a power supply, and also install a DVD+R drive.
I need a little bit of help regarding the power supply and case.
I heard that the Atom 330 processor uses about 55 watts when fully loaded. Graphics and network will come from the built-in chips, hence not much power here. But will be using the two HDs and also burn DVDs at time. What kind of silent power supply would you recommend? I read that the MB is pre-wired to work with the regular Mini-ITX (20 pin) ATX power connector. Can I use laptop-style PSUs, e. g. the ones here: http://www.tranquilpc-shop.co.uk/a [...] ories.html or here: http://linitx.com/viewcategory.php [...] p=149,151? I want a quiet PSU which draws just the right amount of power.
Will the mini-itx motherboard fit in cases made for atx motherboards or do I need a special mini-itx case? And does anyone know of some cool smallish tower cases for the Intel board (need to fit two drives and the regular-sized DVD+R)? The Antec Sonata Solo (http://www.antec.com/uk/productDetails.php?ProdID=08500) seems pretty cool, especially as it features a HD suspension system which minimizes HD noise and protects them from bumps when I move. Also, are there any cases which just have a small hole for a DC power supply cable to enter the case, rather than the big hole in the back for a normal ATX PSU?
Thanks a LOT for any help. :)
Sponsored Links
Don't know about the PSU, but I just used a regular PSU on my Atom build.
Yes, you will need a miniITX case as the screw lay out is different. Mist of the Shuttle type cases will accept mATX and mITX
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
http://www.atomictech.co.uk/istyle.php check this site out its called the iStyle epc and i bought the case of ebay. Its a stylish black mini-itx case with 60w psu, room for a 2.5"/3.5" hdd, slot loading dvd drive and comes with a card reader.
I use it as a media centre pc with vista!
Reply to htpcman83
- 0 +
my question is where on ebay did you find this case. I would like to purchase one my self.
Reply to JAP2871
There are 1087 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
