Diskette Drive O seek failure. Alert! System Battery is low
Last response: in Windows XP
The BIOS is configured to look for a floppy drive that isn't there... go into your CMOS setup and tell it that you have no floppy drive. The "system" battery is the battery that provides power to your CMOS chip so that the settings will be maintained when the power has been removed. It is a button-cell battery (usually CS-232) on your motherboard. Replace the battery and the message will go away.
Ask the community
