Hi,
Can you please have a look at the build below and tell if I am making a big mistake somewhere? I'm mainly concerned about some incompatibility issues that I might be overlooking. I'm building a (primarily gaming) PC for the first time. However, my main concern is to build a quiet PC.
Other considerations: I do not plan to do any overclocking and I try to keep the complete build close to $1,500.
Motherboard: GIGABYTE GA-X48-DS5 LGA 775 Intel X48 ATX Intel Motherboard
(Mainly to go with my 2 GPU cards)
CPU: Intel Core 2 Duo E8500 Wolfdale 3.16GHz LGA 775 65W Dual-Core Processor Model BX80570E8500
(Mainly because of the price and the stock cooler being both cool and quiet)
PSU: CORSAIR CMPSU-1000HX 1000W ATX12V 2.2
(Overkill. Looking for recommendations for a quiet 850W PSU)
Case: Nexus Clodius Quiet High Ventilation PC Case
(I really like this case but there are only a few reviews available. It is not very wide but I won’t need a huge CPU cooler. It’s quiet and I can adjust the fan speed manually)
Memory: OCZ Reaper HPC 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066
Hard drive: Seagate ST3640323AS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s
Video Card (2): GIGABYTE GV-R485MC-1GH Radeon HD 4850 1GB
(Heatsinks on 1GB cards... Got good reviews though. Planning to get two in CrossFire)
Monitor: Acer X193W+BD Black 19" 5ms Widescreen LCD Monitor 300 cd/m2 2000:1 (ACM) 1680x1050
(Or would you recommend a 22” monitor?)
Thanks for taking a look!
