Tom's Hardware > Forum > CPU & Components > CPUs > Q6600 Reach 98-100 heat problem
Forum CPU & Components : CPUs - Q6600 Reach 98-100 heat problem
hi i'm using my q6600 not overclocked on my 64bit xp pro
i'm using virtual dub and look what happaned
anu idea how to fix this ??
http://i42.tinypic.com/2d6k39y.jpg
http://img120.imageshack.us/img120/617/65990113zn4.jpg
More :
http://img12.imageshack.us/img12/1369/p1010302gk4.jpg
http://img22.imageshack.us/img22/2887/p1010303az6.jpg
http://img24.imageshack.us/img24/6097/p1010304he2.jpg
http://img18.imageshack.us/img18/384/p1010305uk9.jpg
Sponsored Links
What software are you using to display the temperature? What is the idle temp in the BIOS? What temperature is displayed by CoreTemp (if you're not using it)?
Reply to GhislainG
core temp and when i'm using virtual dub the temp spike up then i restart the
computer enter bios and see 70 -74 degree
Reply to TazMan
jesus bro... your heat sink looks ancient... clean it off and re apply your thermal paste or get a new one!
------------------------------ E8500 oc'd 4.5 @ 1.44 vcore with 92mm Zalman
ATI 4850 oc'd 680/1158 with aftermarket Zalman
Asus P5Q Pro mobo
2 gigs 800 Corsair ram @ 4-4-4-12
Reply to werxen
I agree with werxen. When you installed the HSF, what thermal paste did you use and how much did you apply? I have a Q6600 with the stock Intel HSF and a thin film of AS5 and it nerver gets hotter that 60°C at full load.
Reply to GhislainG
Not only should you clean the heatsink, but you should also cut out the swiss cheese case fan grate. It's not doing that rear case fan any favors.
Reply to joefriday
what ?? i dont understand i'm not from usa can you explain please ?
Reply to TazMan
What joefriday means is that the rear case fan is inefficient because the airflow through the back is very limited. You could cut out a hole and put a mesh grille to protect the fan. That would be more efficient.
But it won't resolve your immediate high CPU temperature issue. You have to reinstall your HSF properly. Use the correct type of thermal paste (AS5 is pretty good) and only apply as much as required, i.e., a thin film like the thickness of a sheet of paper. Too much or no thermal paste causes issues like you're experiencing.
Reply to GhislainG
that to me looks like a dust build up problem on the CPU heatsink.
just cleanin that out should eliviate most of ur problems,
also all of the recomendations on here are good advice, so please, either replace the cooler with an after market one, or clean it and re-apply the thermal paste and then do some moddin to ur case to allow for better ventillation.
Reply to papalarge123
There are 1217 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
