Okay, so my laptop's LCD is a 1920x1200 native screen. I recently bought a Samsung 2443BWX, also 1920x1200 native. After struggling to make it display 1920x1200 properly, I've now encountered a new issue. Note the video card is a Geforce Go 7950 GTX.
Now, bear with me if this is a general issue with external monitors. It's been awhile since I used one (been on a laptop for a long time).
Anyway, if I'm playing e.g. CoD4 on my laptop's display, in-game I'm able to select a whole ton of resolutions. However if I switch over to my external monitor, it seriously limits my resolution options (i.e. I get maybe 1/4 as many options). Furthermore, if I go to NVIDIA control panel and change flat panel scaling to, say "Do not scale." or "Use NVIDIA scaling with fixed aspect-ratio." then as soon as I enter the game it jumps back to "Use my display's built-in scaling." If I'm on my laptop I can use any of these options.
Is there something I'm missing here? Maybe my monitor and graphics drivers just aren't playing well together. I'm thinking about just returning the monitor. As nice as it is to have a big external display, if lose a ton of flexibility it's not worth it.
I was thinking of maybe trying the BenQ 2400wd anyway, as it comes highly recommended here. Or would I probably have the same issue with that screen?
