Sata II cable ca use in Sata III HD without any speed loss?
Hello,
just bought a new Sata III drive. Do I have to get a Sata III cable or can I use a Sata II cable without any speed loss?
1 answer Last reply
More about sata cable sata speed loss
  1. You do not need new cables - SATA III is designed to be backwards compatible - including the cabling. If you're interested, the SATA.org website has a ton of info, and this pdf is a great start:
    http://www.serialata.org/documents/SATA-6-Gbs-The-Path-from-3gbs-to-6gbs.pdf
Hard Drives SATA Cable HD Storage
