Greetings everyone,
Two days ago I build a pc which contains the following:
Product : Sapphire Radeon HD4850,GDDR3, PCI Express x16, 512MB
Product : OCZ Freeze
2x Product : Scythe Slip Stream, 1200rpm,120 x 120 x 25 mm
Product : Samsung 2253BW
Product : Samsung Spinpoint F1,7200RPM, SATA II, 32MB, 1000GB
2x Product : Samsung SH-S223F
Product : Lian Li PC-7B PLUS II
Product : Intel Core 2 Quad, Q6600, Socket 775, Boxed
Product : Asus P5Q-E,Retail
Product : Corsair TWIN2X4096-8500C5DF,4096MB, 1066MHz, DDR2, PC8500,
Product : Corsair CMPSU-750TXEU,750Watt, Retail
Product : Xigmatek HDT-S1283 plus Bracket.
Everything worked right away I had no problems at all so I installed Vista Business 64 bit on it. I installed many other programs and games and everything worked well. I rebooted the computer a few times because I had to do it due to Windows Updates. And then today when I woke up a problem occurred which probably has nothing to do with the updates because I booted the computer a few times after that and it still worked well. And beside that my problem has something to do with hardware.
So now the story:
I just pushed the power button on my computer and it went on but I didn't saw anything on my screen. It kinda looked like it was in standby or something. So I did the following things to fix it: PC reboot (reset), hold my power button and try to boot it again. I used the on / off button on my PSU and then tried again. I reinstalled all the cables of my monitor and I even took my videocard out and did it back in. And then another weird problemen occured. When I click the power on button on my computer it starts up and then it goes out within 2 seconds and then it goes on and stays on. It also went on automaticly while I was busy with putting the cables back in my monitor. My temperatures of the computer were fine when I checked it my CPU temps were around 19-23 celcius and my motherboard and hdd were around 35 max.
It's very weird because everything worked well and I didn't even touch my case before it went crazy.
I hope anyone can help me and I prefer to try the simplest things first because it's a hard job to take the hardware out because it's a bit full in my case.
Thanks a lot for reading
Greetings,
Qwertyrules
So now the story:
Greetings,
Qwertyrules
