Hey guys, I've been on this site back and forth for the past two weeks or so getting some tips from you folks about a good budget gaming comp, heres what I came up with and tell me if I need something else, or if something needs changing:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021
-Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218
-Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130380
-EVGA 512-P3-N975-AR GeForce 9800 GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135176
-ASUS Black SATA DVD-ROM Drive Model DVD-E818A3T - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371007
-Antec earthwatts EA500 500W ATX12V v2.0 SLI Certified CrossFire Ready 80 PLUS Certified Active PFC Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227267
-OCZ Reaper HPC Edition 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131232
-ASUS P5N-D LGA 775 NVIDIA nForce 750i SLI ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037
-Intel Core 2 Duo E8400 Wolfdale 3.0GHz LGA 775 65W Dual-Core Processor Model BX80570E8400 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116488
-Microsoft Windows Vista Home Premium SP1 64-bit English for System Builders 1pk DSP OEI DVD - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16835101022
-ASUS Lion Square 92mm Vapo Bearing CPU Cooler - Retail
All in all, it costs $1020 and thats with tax and shipping already added. Any suggestions as to changes would be very helpful, I'd like to keep the budget not going over $1200. Thanks!
