Tom's Hardware > Forum > Homebuilt Systems > New System Build > 1300 - 1400 System Build, First time! Help?
Forum Homebuilt Systems : New System Build - 1300 - 1400 System Build, First time! Help?
Hey, I'm going with a AMD build. I have a couple questions though. Do i need a 800Watt to power all of this? Is that too much? Too Little? Is the Biostar TForceTA790GX good with the Phenom 9950? Would i be able to fit my PCI-E TV Tuner with the big 4870x2 Graphics on that MOBO. Which MOBO should i use?? Any advice on the whole system would be appreciated. This is my first build.
LITE-ON 20X DVD±R DVD Burner Black IDE Model DH-20A4P-04 - OEM
Item #: N82E16827106228
Western Digital Caviar GP WD5000AACS 500GB 5400 to 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Item #: N82E16822136149
XION Supernova XON-800R14N 800W ATX12V / EPS12V SLI Certified CrossFire Ready Modular Power Supply - Retail
Microsoft Windows Vista Home Premium SP1 64-bit English for System Builders 1pk DSP OEI DVD - OEM
Item #: N82E16832116488
Sunbeam CR-CCTF 120mm "Core Contact Freezer" CPU Cooler - Retail
Item #: N82E16835207004
NZXT TEMPEST Crafted Series CS-NT-TEM-B Black Steel / Plastic ATX Mid Tower Computer Case - Retail
Item #: N82E16811146047
Skytek 52usbreadwrite2.0 52-in-1 USB 2.0 Card Reader - Retail - COMBO
BIOSTAR TFORCE TA790GX A2+ AM2+/AM2 AMD 790GX HDMI ATX AMD Motherboard - Retail
Item #: N82E16813138128
AMD Phenom 9950 2.6GHz Socket AM2+ 125W Quad-Core Black Edition Processor Model HD995ZXAGHBOX - Retail - COMBO
VisionTek 900250 Radeon HD 4870 X2 2GB 512-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
CORSAIR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X4096-6400C5 - Retail - COMBO
Hauppauge WinTV-HVR 1800 MCE Kit 1128 PCI-Express x1 Interface - Retail
Item #: N82E16815116015
Total - 1361.91 Budget is $1400 /w Mail in rebate its 1281.91
Thanks again!
Sponsored Links
Get a SATA DVD burner, not the IDE one. SATA is faster and you won't have to use the IDE oem ribbon cables.
The Western Digital 640 GB hard drive (SATA again) is only $5 - $10 more then the 500GB one, and it's faster.
Don't go with a Xion power supply, get a Corsair or PC Power and Cooling 750w one which would be fine for this system. I've always had good luck with Biostar motherboards, never had any problems and i like their BIOS set up for overclocking.
Good article to read about CPU scaling with the HD4870x2 here.
http://www.legionhardware.com/document.php?id=770
good luck
Reply to dirtmountain
I heard that the 4870 x2 is so big and with the Biostar having the PCI-E x1 slot right next to the video card slot..that its high possible that the TV Tuner won't fit..
Reply to offwithhishead31
I've decided to put a little more cash down and go all out with the Intel build. Anyone have any suggestions? Good MOBO with this chip?
Intel Core 2 Quad Q9550 Yorkfield 2.83GHz LGA 775 95W Quad-Core Processor Model BX80569Q9550 - Retail
Item #: N82E16819115041
ASUS P5Q Pro LGA 775 Intel P45 ATX Intel Motherboard - Retail
Item #: N82E16813131299
There are 1163 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
