Hello
I have recently been trying to overclock my computer following suggestions by a friend. since I am not to computer literate, I have been experimenting with suggested changes in my bios. I have made some small progress in overclocking .
My motherboard is a GA-38-DS4, Processor is a E8500, power supply is a corsair 750W,
Video card Nvidia 8800 GTX
Here is what happened….. After the last time I entered my bios to make changes in settings including voltage (vcore for the 1st time), after I saved and exited the bios my computer started up but after about 6 seconds it shut down and restarted again for the same 6 seconds and continued doing this over and over until I shut the computer down.
I then contacted my computer tech, he went thru the procedure of trying to clear my bios but when this did not help he called Gigabite support and after working with the tech support they decided my bios was corrupt and I should send the motherboard back for repair or order a new one. I chose to order a new board. Since the motherboard that I had was discontinued I ordered a new model GA-48-DS4. When this board was installed and the computer restarted it once again did the 6 second start and restart all over again with the new board. My computer tech suggested the problem may be with the processor or power supply.
I have reordered a new processor and power supply. Since I was reordering I decided to order an upgrade to a Q9650 processor and 850W power supply.
My question is in advance is if when the new processor and power supply are installed, if the computer still reacts the same way starting over and over again , what should I look for next that may be causing this problem
Thanks for any suggestions
Larry
Larry
