My homebuilt system (specs below) had ran fine for 2 weeks after the initial build. It passed a day on Prime95+, and memtest86 with 10 passes. Until recently, it started restarting randomly. This happens in Windows XP (doesn't matter if its idle or busy), and it would restart even at the BIOS screens.
RAM : OCZ2G8004GK 4GB
CPU : Q6600 (2.4 Ghz) Stock HSF, no overclocking
Motherboard : ASUS P5Q Pro
Video card : ATI AIW X1900
Power Supply : Antec Earthwatt 600w
OS: Windows XP
Here are the things I have tried so far, but still hasn't got it to stop randomly restarting:
1) Ram: Pulled the ram out and tried each individually in different dimms, paired up in slot b = still random restarts, borrowed crosair ram from a friend - still no good
2) Motherboard: Initially thought this was the cause of the problem, so I RMA'd the motherboard; on motherboard #2 now...still same thing
3) Video Card: Bought another one to try Geforce 9600GT; no luck
4) Power Supply: Tried another one no luck either.
5) Hard Drive & DVD-RW: Pulled them both out and tried in a different computer...both works fine.
6) Cooling: Took the side panels off and have a house fan blowing into it..and it still restarts
Now, I am really stumped as to resolving this problem as I have pretty much exhausted all the typical options. The only 2 things I haven't tried changing yet...Could it actually be the CPU that's busted?? How do I go about trying this without having to buy another one?? Also, could a short or something inside the case be causing these random restarts? I have just checked there are no weird medal contacting parts between the motherboard and the case, other than the 9 screws holding it in. Any help would really be appreciated!
Kishle
OS: Windows XP
Kishle
