Hi Everyone,
I'm currently trying to get crossfire enabled with 2 Sapphire HD4850s, however I am running into some problems.
The main problem I am facing is that I am getting absolutely no performance increase with Crossfire enabled. I think this may be because the second GPU appears to be doing nothing at all. I've run a number of full screen applications and having GPU-Z (which reports 2x Crossfire as being enabled) logging the activity of the second card. It seems that the first card does all the work and the second card just idles giving me no FPS increase. Another thing I have noticed in CCC is that in the hardware information that it recognises 2 card a "Primary Adapter" and a "Disabled Adapter"
Anyone have any ideas why this would be happening? I have both the ribbon cables attatched, disabled / re-enabled Crossfire and updated the drivers. I am now out of ideas.
My System (running XP):
- 2 x Sapphire 4850 512MB
- Intel Core 2 Quad Q6600 (2.4GHZ)
- GSkill 2G(2x1G) DDR3 1333 PC10600
- Gigabyte GA-EP45T-DS3R
- OCZ StealthXstream 600W SLI Ready Power Supply(9800GX2 Support)
