I am in the process of upgrading my home network to gigabit Ethernet, and I have run into a problem. I bought two Link Depot C6M-100-WHB 100 ft. Cat 6 White Network Cables which I planned on using to connect two computers to a gigabit switch. For whatever reason they will only connect at 100 Mbps. I have checked the router and computers using a 20 footer I had laying around, and both computers and the router connect at 1 Gbps, no problem. I can only figure that there must be something up with the cable. I checked the reviews, and I don't see that anyone else had this problem. The cable either works or it doesn't.
The other thing I noticed (in case it matters) is that when I first tested the cable, I could only connect at 10 Mbps. The cable, however, was still neatly coiled from the packaging. Upon uncoiling it, it connected at 100 Mbps. I initially wrote off the 10 Mbps speed as caused by inductance in the coil, but with the uncoiled cable still not giving me full speed, perhaps the lower initial speed is a symptom of another problem.
I can only assume it is the cable, but I had always figured the cable will either work or it won't. Plus if there is a manufacturing defect with one, the odds of getting two bad cables are slim. So, am I missing something?
If you've checked under device setting setting for the GbE NICs that 'Speed & Duplex' is set to 'auto negotiable' then there shouldn't be any problem. And you've said a 20ft one works just fine.
It has to be the cable. Check that it's no running parallel to a power line, even for shielded cable they can still cause trouble.
Message edited by wuzy on 06-13-2009 at 01:26:57 AM
------------------------------GTL Ref Tweaking Guide - PM for detail
Brand is for the weak-minded, only product matters.
Resilient to marketing.
Reply to wuzy
Make your own cable. You always know that your cable will not be a problem. Its not that expensive. High Quality 1000ft cable spool is <$100. Its easy to make. You can cut it to exact lenght.
------------------------------Q6600: Maximus Formula: Zalman 9700LED8GByte: Crucial Ballistics 4-4-4-12: PC6400; Vista Ultimate-64BFG XOC 4890; Disp: 70 Inch HDTV: Hauppage 2250 HDTV Tuner1.4TByte: 2x750Gbyte; RAID0; Case: Antec 900: PS:Antec Quatro 850
Reply to leon2006
