Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Motherboard won't stay running
Forum Motherboards & Memory : General Motherboard - Motherboard won't stay running
I have an intel dq965gf motherboard. all of the sudden it stopped running. Now when it is plugged in, the cpu fan starts up for a second then shuts off. The green power light is on and the red light comes on with the fan then shuts of with it too. This keeps repeating until I unplug it. Also, if I remove the 2x2 12v connector, it will stay on but I get no post or anything, but the cpu stays on. When I remove the 2x2, it then goes back to on, off. Is it the motherboard? I've tried different power supplies and I get the same result. Can I fix the motherboard?
Sponsored Links
Are you sure the heatsink is properly mounted.
Reply to festerovic
Yes, the computer was running for about a year then suddenly it stopped, an now this is happening. I've tested everything i can think of. Is it a lost cause at this point?
Reply to maggit13
Have you tried disconnecting ALL the parts of the motherboard? By that I mean: disconnect all hard drives/optical drives and their power cables, remove floppy cable/power, remove all expansion cards (except video if you have one). Make sure all USB cables are removed.
Try removing the battery on the mobo for a bit. Make sure the power to the power supply is unplugged or it won't clear the CMOS. Maybe even get a new battery, they are cheap and found at grocery stores now. Also try removing all RAM, and then install a different stick of RAM in the first slot only.
Get some compressed air and blast the heatsink. If none of these tasks change up anything, it might be time for a new mobo. I would normally suspect PSU, but you said you tried with multiple.
Reply to festerovic
I did all of that. i took the motherboard out and started up that way.
I did some research and found that the heat sink I have on there does not say Pentium 4 support. It looks pretty much like the right one but I ordered another one anyway. Can that make a difference?
Reply to maggit13
Well, my original thought when I read the first post was "That sounds like an overheating/bad heatsink issue". But it has worked fine for a year. Have you ever checked the temps of the CPU while the computer is in use (not BIOS)? You might have slow cooked the chip by running high temps for a long time.
What model CPU do you have?
Reply to festerovic
it's a new cpu, p4 530J, which is doing the same thing as the last cpu that was in it.
Reply to maggit13
There are 496 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
