I've been using a notebook for 2.5 years and am going to try a new desktop build towards the first of the year. I'd really enjoy some input from you guys with experience, feel free to rail me. I'm looking for right at about $1100.
Apevia Cruiser Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811144151
Evga 750i Mobo FTW Edition
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188026
Intel C2D e8500 Wolfdale @ 3.16 Ghz (Will attempt overclock to ~4.3 Ghz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115036
Artic Freezer 7
Evga GTX 260 896mb GPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130370
(Will SLI down the road, hence the large Power Supply)
4 GB DDR2 1066 Mhz RAM (Higher speed to give me more overhead for overclocking)
500gb Seagate Barracuda 7,200 rpm HD
and
Old 120GB HD for Windows Files/Boot (Or is it better to keep all this on the main drive?)
Rosewill 950 W Power Supply 80AMPs total on 4 +12V Rails
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182096
or
PC Power & Cooling 750 W Power Supply with 60AMPS on single +12V Rail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817703009
2 x DVD/RW
Onboard 7.1 Sound
Vista 64bit Home Premium
Thanks for looking guys. I appreciate it.
Brendan
Apevia Cruiser Case
Artic Freezer 7
and
or
2 x DVD/RW
Onboard 7.1 Sound
Brendan
