Tom's Hardware > Forum > Motherboards & Memory > Gigabyte > P35-DS3R Raid - memory installation problems
Forum Motherboards & Memory : Gigabyte - P35-DS3R Raid - memory installation problems
Hi all, I have a GA-P35-DS3R rev 1.0 which ran a RAID1 boot array for WinXP for more than an year.
A couple of weeks ago I started noticing blue screens, driver failures, etc. Then one of the disks in the array appeared to die.
I bought 2 new disks and tried to reinstall WinXP, but I was not able to because of errors in the installation (BSODs).
Once I was able to install WinXP, but everything died when I tried to connect my USB external HD.
I tried to run a memory test (from Ubuntu install disk) and either I got errors, or I was not able to get to the memory test program at all (black screen with blinking cursor forever).
But if I disable raid, the memory test works. Apparently the memory blocks are not faulty, since I get no errors in one config and errors in the other.
Any hints of where the problem is, and what to do? Should I try to install WinXP and patch the BIOS, and then create the array?
Sponsored Links
There are 1311 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
