Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > 9600gt issue plz help
Forum Graphic & Displays : Graphics Cards - 9600gt issue plz help
Hi , I recently upgraded my 8600gt to a 9600gt. Installed it ect but now when i play games i get horizontal flickering lines on dark textures. I know it isn't gpu drivers because i updated them. Im not sure if its a power issue but it shouldn't be because its a 550w which should be plenty. The additional power is plugged in correctly (2x 4pin molex to 6pin pcie).
thanks
Sponsored Links
Sounds like either your GPU is overheating, or there's a driver problem. If those two aren't the issue, your GPU may be bad.
First thing I'd check is to see if the same thing happens in other games/software. It could be a drive conflict with the particular game/software.
You might try installing an older driver to see if the problem goes away. And then check your temps on the GPU.
If temps are good, different drivers don't help, power is determined not to be the issue, and the same problem appears in multiple games, you may just have a defective GPU.
------------------------------ i5-750 4Ghz @ 1.32V / Gigabyte GA-P55-UD4P / Xigmatek HDT-S1283
2 x MSI GTX 260 Core 216 SLI (655Mhz) / 4GB GSkill DDR3 1600 9-9-9-24 @1.5v
2 x WD Caviar Black 1TB / Thermaltake Armor BWS8003
Win 7 64bit / Antec TPQ-850 / 3dMark06 24621
Reply to jerreece
the temparatures are fine and it appears in all the games i play (oblivion, gunz, dawn of war and age of empires 3)
im just curious, this is the psu i have http://www.novatech.co.uk/novatech [...] NOV-PSU550 it is ok for my gfx card right?
Reply to xblackskiesx
The power supply looks like a winner...( and I don't mean that in a good way ). There were some issues with over clocked cards. Did you try and under clock it at all ? Which one do you have ?
Reply to swifty_morgan
http://www.novatech.co.uk/novatech [...] l?NOV-96GT this is the card i have. and also, how could it be the psu ? A friend of mine has the exact same psu but he has a 9800gt super plus and his works fine. and the minimum wattage for a 9600gt is 400 .
I'd imagine your power supply isn't helping. Not familiar with that brand, but look at its specs, they don't actually give the 12V amperage. It only says, "10A res max. for 115VAC". If it only had 10amps on the 12V rail potentially, that's not going to work for you.
Reply to jerreece
It's more about amperage than it is about wattage. You could have a 1000W power supply, but if it doesn't have enough amperage on the 12V power lines (for video card) it won't work.
Either your PSU isn't giving the video card enough power, or your video card is bad.
Reply to jerreece
damn are you sure ? Can you recommend me the cheapest psu that would be sufficient. like i say in my other post a friend has the exact same psu with a more powerful gfx except he has no issues
It's rated for 25 A on the 12 volt rail.
Reply to Jim_L9
any 500w psu from corsair/enermax/antec/ocz will do. afaik they dont sell underpowered volt-rail products.
Reply to wh3resmycar
There are 736 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
