Like the title says, I have decided to take the plunge into making my first build. Right now I'm looking at:
Intel Core 2 Quad Q9550 2.83GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115041
GIGABYTE GA-EP45-DS3L LGA 775 Intel P45 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128345
CORSAIR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145184
EVGA GeForce GTX 260 Core 216
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130398
CORSAIR CMPSU-650TX 650W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
WD Caviar 640GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218
Antec P182 Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129025
SAMSUNG 22X DVD±R DVD Burner with LightScribe
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151173
Should I get this too?
ARCTIC COOLING Freezer 7 Pro
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134
I'll be using this for decent gaming and Maya, and am looking at keeping the price below 12-1300. Those parts are about 1,100 right now. Also, I'll be getting Vista 64bit. I also don't see myself overclocking much or getting a second gpu.
Thoughts?
WD Caviar 640GB
Antec P182 Case
Thoughts?
