Hi everyone,
I am about to build a new system and I am choosing my card and case, but as I read some reviews I am worried that the card I chose might not fit into the case I selected?!
Nice choice of card.
According to the case specs the lowe HDD cage can be removed so you`ll have plenty of room, you`ll just have to put the drive/s elsewhere.
And you may need low profile SATA cables, on some MBs the card overhangs the SATA ports.
the stuff with the sticky backing . You peel off the paper and press it in to place . Two strips about 3 inches [ 75 mm ] long on the top of the hard drive and two more where ever you want to mount the drive .
Theres usually a spot to mount a hard drive vertically against the side of a case if the gfx card is too long
