Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Nvidia > Forceware 180 Drivers Fan control problem
Forum Graphics & Displays : Nvidia Forceware 180 Drivers Fan control problem
Has anyone else noticed you lose fan control in N-tune with the new 180 drivers? I loaded them this weekend and went to set my OC again and the fields are greyed out. Bugges me that i cannot set my fan speed and my GPU is running at 63c idle now whereas i was at 43-45c idle at 50% fan. any help appreciated.
Reply to hacker91
Yes. I was using Smart Doctor for fan control, and after the driver update, it quit working. I'm leaving it for now, as the card is doing OK, temp. wise, but it is bugging me enough to consider the following to absolutely fix any potential fan control problems;
- remove fans from CPU and GPU, and set them up and let them run somewhere beneficial (one directed at ram sticks, one to aid case cooling, for example) this way, I would have no issues or warnings, the mobo and GPU wouldn't think anything was wrong.
- install aftermarket fans on the CPU and GPU, tied directly to the 12V from the PSU, through 2 nice control knobs mounted on the side of my case.
Absolute control ensured forever.
Reply to Wrecks
Same problem here...
Just tried rivatuner and you can control the fan there aswell. You can even make fan speed profiles so you should deffinetly check that out.
Reply to radium69
Hi
I have the same issue, lost my fan controle with the 180 drivers.
I m using RIVATUNER to correct the problem.
Reply to Laserman1
I dumped the 180 drivers after I had stability issues while gaming, plus the lose of the fan speed control was annoying.
Reply to 98silvz71
Yep, same here...I thought maybe it was just my system as the release notes say nothing about fan control being hosed. As mentioned, just use RivaTuner. You definitely want manual fan control as GPU temps get too high with the automatic control.
Reply to Orion1024
There are 1875 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
I need a new video card - Help?
By Pinhedd, 7 hours ago:
6670 1GB hands down. The 6570 is less powerful and has inferior GDDR3 RAM which is vastly...
Best offers
Top experts
