Installed xp pro on an emachine and sound quit working. says no sound device
rmnease1
I installed xp pro on an emachine EL1300 and now there is no sound. Says there is no sound device. Can anyone help....Thanks Mike
Double click the speaker icon in the lower right hand of the desktop, this will bring up the mixer, or single click to bring up the volume control.
But in case the volume is missing, corrupted, or the audio is otherwise non-functional:
you check whichever audio was installed:
click start, control panel, add remove programs, look at the list...
which audio software is shown on the list? delete it, restart the computer.
now visit the motherboard manufacturer or computer manufacturer's website
look up your computer drivers by model number
download the latest audio drivers, save on the desktop...
turn the antivirus off,
if you have multiple security programs installed, turn them all off
(your driver may not install if security systems are turned on)
now load your new audio driver, restart, turn the antivirus back on.
Let the forum know if that solves the problem. SGM
rmnease1
Thanks my friend!! It worked. Now can you fix the government? lol j/k
