Tom's Hardware > Forum > Graphic & Displays > ATI > VEDIO AND SOUND CARD QUESTION?.
Forum Graphic & Displays : ATI - VEDIO AND SOUND CARD QUESTION?.
I have a ATI Radeon Sapphire HD 3870 it also comes with the HDMI thing you plug in,and high Deffintion Sound driver what does this stuff mean, what does it do for me.
whats HDMI?.
Does this Vedio Card have a sound card in it to?.
Sponsored Links
No need to shout pal.
Your gfx card has an audio pass through chip on it to enable HDMI signals to be passed through to a receiver.
------------------------------ I'm a git, deal with it.
Antec 1200,PC Power & Cooling 750,Gigabyte DS4-x48,Intel Q9550@3.4 W/Xigmatek S1283,8GB OCZ DDR2 800,ATI 4870X2,X-FI>CA 640C amp>Tannoy R300/Senn 595's
Reply to strangestranger
- 0 +
I wasn't shouting.
Thanks for Feedback, but what does HDMI do
Reply to wind_09
- 0 +
Can i have High Diffention sound on my computer, from this graphic card.
Reply to wind_09
- 0 +
if you have a hdtv with a hdmi input as a screen then yes.
Reply to montyuk
HDMI is just a connection standard based on dvi that allows multi channel sound to be simultaneously transmitted with the images, used in turn with HDCP it can allow encrypted data to be safely transmitted, however it should be noted that dvi is also perfectly capable with an adapter.
Oh and using caps is how you shout in text.
This is a relativily complicated issue that i do not have the knowledge to explain and should be searched for rather than asked.
HDMI is essentally a digital signal, just like DVI. The only diffrences is the connection is smaller, and that HDMI also carries audio, and not just video.
Reply to gamerk316
http://img253.imageshack.us/img253/6026/justgoogleitzs9.gif
Message edited by TheGreatGrapeApe on 12-17-2008 at 07:02:16 AM
------------------------------ You need a license to buy a gun, but they'll sell anyone a stamp (or internet account) - RED GREEN. GA to SK
HD Freedom: 45 5F E1 04 22 CA 29 C4 93 3F 95 05 2B 79 2A B2
Reply to TheGreatGrapeApe
There are 776 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
