Am I reading this correctly? Reason is I have a 425 W Power supply..I want to get an 8800 GT-a friend of a friend is selling his card since he is starting grad school. I know minimum power supply is 400 W..I have that covered..but I don't like to live that close to the edge..if max power consumption under 3D conditions is even 320 or below..I will feel safe..So am I reading it correctly? It is a quality power supply.
This was the setup for the test
CPU
Intel Core 2 Duo E6850 (3 GHz)
Motherboard Asus P5K3 Deluxe
Memory Kingston 2 x 1024 MB setup in DDR-3 800 5-5-5-15-21
Hard Drive
Message edited by jamesrwright on 12-16-2008 at 04:21:41 AM
I am confused though.,.I see people on the forum having trouble with a 8800 GT 425 W power supply. Why would they be having trouble? I just don't want to throw $100 down the drain.
It's not just about watts, you need the amps on the 12v.
An 8800GT should have a 24-26amp psu to be ok.
------------------------------ P35-DS3L Rev 2 bios F9C l E8400 @ 3.6Ghz @ 1.232v l OCZ Vendetta 2 /LGA775 Bolt-Thru l 4GB G.Skill 8800PI@1000mhz 4:5 @ 1.87v l WD3200AAKS 320GB l Evga 8800GTS 512 l X-Fi Xtreme Music l Corsair HX520 l Antec Sonata III 500 l Vista32 SP2 l Win7 X64 7600
Reply to kpo6969
I'm running a 4850 on a fairly poor 550W power supply. The 4870 does use a good 40-50W more though. I don't know much about the quality of BFG PSes (quality makes a huge difference. My 550W can't actually supply 550W like a high quality PCP&C could).
------------------------------New Build (Under Contruction): Intel Core i5 750 > Gigabyte GA-P55-UD4P > 2x2GB GSkill 1600MHz CL7 1.65V > Samsung Spinpoint F3 1TB > Antec 300 Illusion > Asus 4850 512MB w/AM Cooler > Corsair 650HX > Hyper 212 Plus > See other Builds in Member Config
Reply to EXT64
