Tom's Hardware > Forum > Motherboards & Memory > Asus > Motherboard or power supply problem
Forum Motherboards & Memory : Asus - Motherboard or power supply problem
I built a computer using Asus P5Q motherboard. It was working fine till yesterday. Since today however, on power on, it starts and then stops and starts again. However, i don't get any display. I tried taking out the GEForce display card to see if it was a power supply issue. However, it still happens. All the fans seem to be running fine.
Any help is appreciated.
Thanks,
S
Sponsored Links
To start with try clearing the CMOS, do it as the manual says.
Reply to MaDMagik
This just happened to me. Did the same thing, pulled the graphic card, no fix. Tried another PS, no fix. I thought it was a MB problem and tried a new P5Q, but that didn't fix the issue. Turned out all my memory went bad, all 4 DIMMs. RMA'd the memory and was back in business when it was replaced.
Reply to lcgalloway
The same's happening to me. Mobo: Asus P5Q Pro. Sometimes it boots, but often won't POST. I've already exchanged the RAM modules to different makes, but nothing changed.
Reply to KarnEvil
Please post your full system specs including the PSU brand, wattage and +12v amperage and any overclocks.
Use Memtest to test your RAM if you think it is at fault.
------------------------------ If the automobile had followed the same development cycle as the computer, a Rolls-Royce today would cost $100, get a million miles to the gallon, and explode once a year, killing everyone inside.
PSA
Reply to outlw6669
First thing is clear CMOS (removing any OC set there). Remove all but one RAM stick, and try.
------------------------------ There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
Thanks,
S
It could be something very simple like a loose connection
1. Check the power cord to the power supply
(both at the PSU and the surge supressor)
2. Check the connections from the power switch on the PC to the M/B
3. Try moving the Display card away from any heat source and make sure it's seated properly seated
4. Recheck all other power connections if above doesn't correct problem
Reply to auntemame59
You could also check this checklist out seems to be pretty good. http://www.tomshardware.com/forum/ [...] -checklist
Reply to drippyfausett
I've bought an Antec Truepower Trio 650W today, it has 8-pin CPU plug.
I wanted to have it anyway, but unfortunately it didn't solve the problem.
First power switch-on: vents on, black screen.
Second power switch-on: vents turned on, and then off, and then on again, POSTed, error message from Windows.
I pushed RESET and it POSTed and Windows started...
So, I have already changed RAM modules and PSU I think these are fine.
I've already reset CMOS, updated firmware. (Now it's 2002.) What else can I do?
Reply to KarnEvil
The mobo was faulty. I got a replacement and it works nice.
Reply to KarnEvil
Hmmm, all's well that ends well.
Reply to jtt283
There are 1082 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
