Currently running an
e8400 @stock
asus maximus formula x38
hd5870 @875/1250
corsair 750tx
in a CoolerMaster Sniper w/ 3x 250mm fans
First and foremost, I play BFBC2 @ 1920x1200 at high everything 4xAA/16xAF
Ive been getting frame drops during intense moments (expected) but I want to change this. (hence the mild VGA oc)
My temps have been up in the high 70s-80s under full load.
I adjusted fan speed in CC and set it to 40%.
This will keep things under 72* at load, which is good, but too loud.
I am considering setting up eyefinity w/ 3 1920x1200 monitors and I figure I will probably want to get another 5870.
I dont think I am digging all the fan noise in my case. (neither is the female)
I also plan on grabbing a Thurban processor when they release.
Does water cooling sound worth it?
Im not concerned about price.
I would like a quiet, great performing system that can handle some mild over clocks.
Anyone have any recommendations?
Im currently looking at the EK clear copper blocks and the swiftech Komodo for my Vga's
I am stuck on which pump may be good AND quiet.
Is 1/2" i.d. better to go with considering I would need to accommodate 2x vga>cpu?
Should I go with a chipset block if I am not doing extreme o.c.ing?
e8400 @stock
hd5870 @875/1250
corsair 750tx
