Now we all know that overclocking uses more power escpially when you add voltage. What I was thinking about today was how much does power usage go when you raise the clock speed but not the volts. I'm thinking that it wouldnt go past the chips tdp rating on stock volts.
I have seen plenly of the OC charts with power consumption in them but I dont recall any that had overlcocked the cpu with stock volts.
Intel and AMD both have cpus now that can get a nice overclock with out adding volts. Heck alot of the chips can take a voltage drop if anything.
Anybody have any info on this. For example if we were to take a e7300 and overclock it to e7500 speed on stock volts about how much more power do you think it takes. I know its impossible to get it exact, you cant even get the same results from 2 of the same cpus due to the VID/binning. But just a figure in the ballpark.
