My P4 system is aging, and I really want to play GTAIV , but I need some advice on my potential setup. Could you guys help me out?
Goals:
-To play GTAIV smoothly on high settings (or maybe mid-high)
-not be too expensive. I don't have a set dollar limit, but I don't want to go too far over what I have below. At the same time, if there's a place where I could save some $$, let me know.
-a fairly quiet system
-I will never use a 2 graphics card setup
-I have never overclocked before, and I haven't decided if I'm going to start
-I'm not a huge gamer, but I like to play games occasionally
What I already have:
-a 22" widescreen monitor (1680 X 1050 resolution)
-OCZ Stealth XTreme 500W PSU that's about 2 months old (I'd like to save a few bucks and use this, but if I need something more powerful, let me know). Here's the link to the PSU I have:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341012
-keyboard, mouse, speakers, printer
My list:
ASUS EAH4850 TOP/HTDI/512M Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
$170 ($140 with rebate)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121272
Intel Core 2 Duo E8400 Wolfdale 3.0GHz LGA 775 65W Dual-Core Processor Model BX80570E8400 - Retail
ASUS P5Q Pro LGA 775 Intel P45 ATX Intel Motherboard - Retail
combo price: $250 ($235 with rebate) (I can't figure out how to link to the combo, so I'll link to the individual parts)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131299
G.SKILL PI Black 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL4D-4GBPI-B - Retail
$45 with promo code HARDOCP11245
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231209
Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
$70
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler - Retail
$32 ($22 with rebate)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003
XIGMATEK ACK-I7751 Retention Bracket - Retail
$8.50
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233019
case:
I have no idea, help me out. I heard that on 11/26/08 newegg will have the Antec 900 for $60 - I'm thinking about that, but I don't want a case with all those lights. Is there a way to disable the lights? Or do you have any other suggestions? Also, I have a microcenter and a Best Buy nearby (shipping for cases can be expensive)
OS:
Vista Ultimate
$65 (I don't think I need Ultimate instead of Home Premium, but since I'm a student, this is cheaper)
http://www.microsoft.com/student/discounts/theultimatesteal-us/default.aspx
Total before rebates: $705
Total after rebates: $645
(this assumes I buy a $60 case)
Questions:
Should I go quad core? Or would the E8400 be good enough for GTAIV?
Will my current PSU be sufficient?
Should I go with 32 bit or 64 bit Vista?
Any other suggestions?
Thanks in advance for your help, I really appreciate it
Goals:
My list:
$70
$8.50
case:
OS:
Vista Ultimate
Questions:
