Best Case for i7 system
I'm building a new i7 system from the ground up. I'm getting the 920 processor, 6GB Corsair ram and Asus P6T Motherboard. Looking for suggestions for the best case to put this in. I'm going for function over any appearance. It will house 4 or 5 HD's. What I'd like is one that has good cooling, easy to work on and from someone that has good instructions. I've built a couple but not enough that I don't appreciate good documentation. I like the Cooler Master RC-1000 but wish it was just a bit smaller. Something in the $150 range or less would be good but I'd stretch that if it meant a real improvement. Any thoughts appreciated.
16 answers Last reply
More about best case system
  1. i mean the antec 1200 is a killer case. do you need a full tower or a mid tower. i personally think the antec 900 and nzxt tempest are solid mid tower cases. the tempest can take up to 8 HD but i think you need to remove the HD cage fans if you use all of them. no big deal because there are already 6 fans in the case and cooling shouldnt be an issue. i think its a steal because even though its mid tower it really compares to a full tower case. people sometimes call it a Full Mid tower case. boo yah
  2. That nzxt tempest does look like a nice case. The last one I built I used an Antec P182. I like the quality of construction but don't care for the slide in enclosere for the drives and find that with the stiff power cables they tend to really stress the point of connection to the drives. Th nzxt tempest looks better to me in that respect.
    I don't need a full size tower but would like one where I'm not cramped adding drives etc. If that Cooler Master came in a similar mid tower I'd get it. One thing I don't care for about that Antec case is the led fans etc. Can you disable them easily?
  3. i know, i totally agree, i mean they look awesome for the first 5 mins but i can see them getting very annoying. unfortunately i do not now of any way. i am sure you can disable them but that would physically require you to cut a wire or break the lights.
  4. yeah unless you wanna ad a switch or permanently disable them i see no easy fix. try searching mid tower cases on newegg and make sure you sort by best rating. see what you can find. i think full tower is just too big for a non server, extreme enthusiast build. what kind of video card do you plan on using?
  5. i would go for the Antec 1200 or 900 at least for their superior cooling because apparantly all i7 CPU is heat monster.so cooling is essential.
    Oh, I don't mind permanently doing away with the leds. Great to know the cases with them are an option as long as I can "fix" them. Nothing extreme on the video card. Going with an ASUS Radeon 4850. This is mostly for Photoshop and similar work and is pretty much like the Falcon Northwest Talon which I've heard good things about.
    I know most here are gamers and from what I've seen you guys are the ones that offer the most knowledge on custom builds! Thanks.
  7. Check out the Coolermaster 690 too. It's just an inch or so bigger than the Antec 900.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
    Or if you're an NVidia fan... check out the NV 690 nvidia version. It's on sale till tomorrow!
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119157
    FYI, the antec 900 is going to be on sale on black friday at newegg.
  8. Those are both nice cases. I like the antec 900 especially. Wish it had an esata port on the front but I can live with that if I have to. Any idea what the Black Friday special is on it?
    Thanks
  9. Might want to check out the Antec 300. Its about the same size as the 900, has no Led lights, no goofy window, is about $40-60 and has lots of airflow. Need to buy 3 120mm fans and a 120mm dust filter for it, but that gives you the option to pick the quietest fans... like sharkoon golfballs from Performance-PC.
    Thanks
    Yeah. $59.99 is what the email said (there was a "sneak peek" email that came out)
    here is a pic of it:
    http://promotions.newegg.com/NEemail/Nov-0-2008/preBF24/images/INDEX_3a.gif?nm_mc=AFC-SlickDeals&cm_mmc=AFC-SlickDeals-_-NA-_-NA-_-NA
    There is an astrix by it, so I don't know if that means combo deal or early bird or what.... just fyi.
  11. Boy, that's a great price for a case that gets good reviews. Not exactly what I'm looking for but it will get the job done. Unless something really grabs me I'll probably go for it. Thanks for that link.
  12. Yeah the 900 is $60 on Black Friday.
    I spent $130 on it like 2 years ago. Great case.
  13. Yeah, I see it up now. $59 with free delivery and no rebate to deal with. Wouldn't be my first choice but hard to turn down. I'm surprised there are only a couple of cases on their Black Friday pages. I was sort of hoping that Cooler Master 1000 would go on sale. I know it's bigger than I need right now but I just like the layout of the thing inside and out with all the USB ports along with esata in front. Actually I did find it on Amazon delivered for what Newegg is +shipping.
  14. The people on this thread know there stuff. Antec 900 or 1200 (or Coolermaster 690) is the way to go. You gotta keep that Core i7 monster cool!
  15. Oh man, I don't doubt that for a minute! I didn't think anyone was saying that the Cooler Master 1000 wouldn't work but did just see one review that says the 3.5" drive layout was not cool at all for the drives. That 900 is looking better now.
New Build Cases Intel i7 Systems Product
