Tom's Hardware > Forum > Homebuilt Systems > New System Build > Help w/ 1st built PC Please!
Forum Homebuilt Systems : New System Build - Help w/ 1st built PC Please!
Here are my current parts that I have bought...I am waiting on more specials to arise before/after BF. I need help w/ selecting the rest of my parts such as HD, PSU, Tower Case, cooling fans, etc. This is my 1st build and would like to keep it budget friendly, so I need to know what type of power supply, casing, tips, etc. Any tips or hints are greatly appreciated!!Thanks for your help!
1 x ($76.00) CPU AMD|A64 X2 6000+ 3.1G AM2 1M RT - Retail $76.00
http://www.newegg.com/Product/Prod [...] 6819103272
1 x ($44.99) MEM 2Gx2|GSK F2-6400CL5D-4GBPQ R - Retail $44.99
http://www.newegg.com/Product/Prod [...] 6820231122
1 x ($65.99) MB ASUS M3A78-EM AM2+ 780G/SB700 RT - Retail $65.99
http://www.newegg.com/Product/Prod [...] 6813131324
1 x ($-10.00) DISCOUNT FOR PROMOTION CODE$-10.00
Sponsored Links
Get the EA650 from newegg. It's an insanely good deal at 50 bucks.
http://www.newegg.com/Product/Prod [...] &Tpk=EA650
Reply to Proximon
Here's a steal of a deal on an Antec Sonata III case/PSU combo! It's $75 shipped and you get the case and the 500w Antec Earthwatts PSU, which is >80% efficient and has 34A on the 12v rails!! Deal is good until 11/26!
Antec Sonata III 500 Black 0.8mm cold rolled steel ATX Mid Tower Computer Case 500W Power Supply - Retail
HD - $70 shipped! One of the better and faster HD's out right now!
Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM
Total is $145 shipped!!
That should do it, unless your looking for a GPU too?
------------------------------ PSU Tiers
GPU Power
8800gtx w/e6600 OC'd will run on Antec 380w w/27A on 12v rail, PSU!!
Reply to lunyone
Thanks guys for the info...I am thinking the Antec case w/ PSU will do and maybe the WD HD as well. Is the graphics card on my CPU suitable or should I look at getting another graphics card. I would like to play Flight Simulator X in about 30fps if possible on the highest settings. Any help w/ this?
Reply to absurdgoat
:o
You'll need a quad core CPU and a serious graphics card to do that. Maybe you can pull it off at a low resolution... say something like this:
http://www.tigerdirect.com/applica [...] &CatId=164
Reply to Proximon
You'll need quite a beefy system to get Flight Simulator X at 30 fps. You should get a dedicated GPU if your going to do some decent gaming. Did you have a budget for the parts you need?
GPU Power
Reply to lunyone
:non: Flight Simulator is a pain, so you're probably going to need to spend alot more money to play it on max settings. You may want to take a look at this article
http://www.tomshardware.com/review [...] 964-6.html
and if you look at the results it would seem that the test is CPU limited even with an Intel 6850 which is the ol quad at 3.0GHz. If you're looking at a budget card then go with a Radeon 4850 or 4830 or an nVidia 9800 series card if you can find it at a good price that fits your budget. With that, you can play it at pretty decent settings, but probably not max.
Reply to megamanx00
$75 or less...I know that isn't much, but there are some really good 512mb DDR2 cards out there, maybe they can't play FSX at 30fps, but I am just a casual gamer so something around that price should suffice.
Thanks!
Reply to absurdgoat
Great article on FSX! Thanks, that will help me decide on a nice GPU.
Reply to absurdgoat
The 3870 on the charts is close to a 4670 GPU, so keep that in mind when looking for deals.
Comparison of a few 3870 cards. They are older cards by todays standards, but are decent GPU's by themselves.
Comparison of several 4670 GPU's. They are about 10-20% cheaper and don't require any additional PSU power to run them.
See image below of the 6 pin PCI-e power connector that the 3870 GPU requires to run. I have used a 9600gt GPU to show you what the 6 pin PCI-e power connector looks like. If you get the Antec Sonata III case your covered, because the PSU has the necessary 6 pin PCI-e power connector!!
http://c1.neweggimages.com/NeweggImage/productimage/14-127-333-07.jpg
Message edited by lunyone on 11-26-2008 at 07:16:22 AM
Reply to lunyone
Newegg plans on selling the Antec 900 for $60 as a Black Friday special.
Reply to Slomo4shO
Yep, but he'll still need to get a PSU too, so the $75 deal for the Antec Sonata III case/PSU combo will be hard to beat, unless they offer it cheaper on BF.
Reply to lunyone
FSP has a clearance on their PSUs with savings up to 80% off. Use the promo code "TURKEY" for an additional $10 off. You can get a FSP400-60PNU for $4.99 with free shipping!!!
Reply to Slomo4shO
lol thats my exact 9600GT :D
Reply to V3NOM
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=290275168425&ssPageName=STRK:MEWN:IT&ih=019
I have this ATI Radeon X800XT graphics card laying around w/ a 300w PSU. Would it be wise to install this graphics card and PSU or keep the graphics card that's on the mob?
Reply to absurdgoat
There are 763 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
