Tom's Hardware > Forum > Homebuilt Systems > New System Build > [New System Build] First build Need Help
Forum Homebuilt Systems : New System Build - [New System Build] First build Need Help
I think I may have it figured out.... first build
Case: Antec 1200
http://www.newegg.com/Product/Prod [...] 6811129043
CPU: Intel Core 2 Duo E8500
http://www.newegg.com/Product/Prod [...] 6819115036
Motherboard: ASUS P5Q Pro LGA 775 Intel P45 ATX Intel Motherboard
http://www.newegg.com/Product/Prod [...] 6813131299
RAM: OCZ Reaper HPC Edition 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
http://www.newegg.com/Product/Prod [...] _-Homepage
PSU: CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC
http://www.newegg.com/Product/Prod [...] 6817139006
Harddrive: Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s
http://www.newegg.com/Product/Prod [...] 6822136319
Video card: ASUS EAH4850 TOP/HTDI/512M Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16
http://www.newegg.com/Product/Prod [...] 6814121272
I need a cpu cooler, I dont know what to look for. Also I'm not sure about the video card and the ram.Any suggestions comments criticisms are appreciated.
Sponsored Links
The cooler on the video card is very quiet, but you can't really alter the fan speed if you feel it's not providing enough air. As for the CPU cooler you may want to look at this XIGMATEK Rifle cooler
http://www.newegg.com/Product/Prod [...] 6835233014
and the retention bracket
http://www.newegg.com/Product/Prod [...] 6835233020
Or you could spend a little more money and get this copper beast from Zalman
http://www.newegg.com/Product/Prod [...] 6835118019
I say go with the Rifle cooler though.
Reply to megamanx00
- 0 +
I'd try the stock Intel cooler first. I lower the fan rpms using a program in the bios.
Reply to o1die
- 0 +
intel stock coolers are only just minamal you will find that you will get high temps, i would buy an after market cooler like a OCZ venetta 2 or something, anything is better than stock xD
Reply to AMG
There are 942 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
