[skip this if you like] Ok, i have one of the worst mobos i could. anyway, I want to get the Thermalright Ultima 90 because here the ambient temps. are quite high - above 90F and at times by Q6600 reaches temps. above 90 C (i reseated the heatsink several times, so the thermal compound cannot set.) Instead of getting a new thermal compound, I think it would be better to get a new HSF as this would also be useful for future Ocing on different mobos.
bottom line- I want to install a Thermalright Ultima 90 on my Intel DG31PR. Can I install the backplate comfortably or will some soldering in the back obstruct the backplate?
------------------------------Intel Core 2 Quad Q6600 @ 2.4 | Thermalright Ultima 90 120mm fan | Intel DG31PR | 4 GB DDR2 @ 800MHz | HD 4850 512 GDDR3 | Corsair VX450 | Samsung 22x DVD RW | Windows Vista HP 32-bit/ Windows 7 64-bit dual boot | Samsung SyncMaster 19" LCD VGA 920NW |
What thermal paste are you using? Thermalright should be able to confirm if that HSF will work with your Intel motherboard. Intel usually build motherboards that are clean in the back.
If you removed the OEM HSF, you need to clean the old paste and replace it with Artic Silver 5 or equivalent thermal paste. Otherwise your CPU will overheat.
Few people install such a HSF on a motherboard like yours. Contacting Thermalright still is your best option. Is there anything sort of abnormal under the CPU area with that specific motherboard? I've bought a few Intel motherboards (and I still have one) and they were nicely built.
