Tom's Hardware > Forum > Homebuilt Systems > New System Build > Please help! New build and need to buy before thanksgiving!
Forum Homebuilt Systems : New System Build - Please help! New build and need to buy before thanksgiving!
Thanks for looking :)
This is what I am looking at:
NZXT Alpha Black Steel ATX Mid Tower Computer Case with Open Window
http://www.newegg.com/Product/Prod [...] 6811146041
GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard
http://www.newegg.com/Product/Prod [...] 6813128358
Intel Core 2 Duo E8400 Wolfdale 3.0GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor
http://www.newegg.com/Product/Prod [...] 6819115037
CORSAIR CMPSU-520HX 520W ATX12V v2.2 and EPS12V 2.91 SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Prod [...] 6817139001
CORSAIR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X4096-6400C5
http://www.newegg.com/Product/Prod [...] 6820145184
Here is an image of my shopping cart with all this:
http://img512.imageshack.us/my.php?image=cartir0.jpg
The urgency(sale ends tomorrow) is mainly on case, psu, and ram (psu and ram in a combo)
Note: No video card, hd, optical drive, monitor, speakers, keyboard, mouse, operating system
I have everything but video card and hd
for hd, I might get this:(sale ends today)
http://compusa.shoplocal.com/compu [...] USA-081126
Video card:I will buy that later(I will be patient for good deal). I can make the computer without a video card, right? (I just can't do anything graphics intense)
Does the build sound good? Do I need to change anything? If I get a good video card, will it be able to play crisis 30fps+ at 1680x1050?
Plz answer quick, as I need to buy this before today ends (Or at least psu,case,ram, and possibly hd)
Thanks!!!!!!!!!!!!!
Sponsored Links
first if you have no video output you won't be able to build the computer. your motherboard has no onboard GPU thus you have to have a GPU to even get the system running let alone playing crysis
as for the rig it looks really good
i would recommend a 4850 or 4870 graphics card depending on your budget
as for crysis depending on the GPU you should get 30+ FPS on moderately high settings
overall great but you will need a GPU
Reply to rammar16
"Sale ends today"
but black friday and cyber monday are just around the corner
Reply to mtyermom
What you have looks good but you might have to purchase a larger power supply if you plan on getting a good video card for a game like Crisis because being able to run Crisis at 1680x1050 at 30+ fps would require something like a 4850 or 4870 at minumum. Other than that, your parts look good.
Reply to MrBradley
Alright, definately need video card then :)
Black friday is already here for newegg, I'm guessing cyber monday won't be that great.
laskjdlksjdfkljsdflkj with the psu. Out of researching for this computer, I have learned the most from psus b/c people keep telling me bigger, bigger, better, when is it going to stop?!
Is +3.3@24A,+5V@24A,+12V1@18A,+12V2@18A,+12V3@18A,- 12V@0.8A,+5VSB@3A not enough??
I have to go get that harddrive... very soon (have to go to store). Does it look adequate? I don't know much about harddrives and previously thought they really didn't matter much besides rpms. Is that hd ok?
Thanks for the replies
Reply to theicfire
Seagate is ok but I prefer Western Digital. There are more dead Seagates in my store than there are Western Digitals.
Reply to MrBradley
There are 971 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
