Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Palit Hd 4850 Problems
Forum Graphic & Displays : Graphics Cards - Palit Hd 4850 Problems
Hi, I am new here and my English is horible so,sorry about it!
My pc is :
Intel Dual Core E2180 2Ghz (2.6 Clocked)
Palit HD 4850 512mb DDR3 256bit
Asus P5B-VM SE
2X2 Gb Ram DDR2 800mhZ
320 GB Samsung
350PNF W Fortron
I changed my Hd 3650 with HD 4850 and seen some problems in almost all of the games that I play!
For Example NFS Undercover now running very bad in all ways and resolutions! And with over 40 Fps i have slowdowns nad little stops( I dont know exactly the word...)
Crysis evan with 30Fps and over i have same results like in NFS!
Do you think that my C2D E2180 is the problem nad after I upgradet 3650 with 4850 he having troubles with that?
I am about to buy C2D E8400 will this help ?
P.S I just dont get it! Why when I have over 40-50 frames I cannot play smooth! ? Thanks a lot and onse again sorry for my English. "Greetings from Bulgaria"
Sponsored Links
Welcome to the forums!
ATI Radeon HD 4850 System Requirements
450 Watt or greater power supply with 75 Watt 6-pin PCI Express® power connector recommended (550 Watt and two 6-pin connectors for ATI CrossFireX™ technology in dual mode)
Certified power supplies are recommended. Refer to http://ati.amd.com/certifiedPSU for a list of Certified products.
Merry Christmas!
Message edited by evongugg on 12-24-2008 at 03:28:19 PM
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
There are 1218 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
