Budget: $500-550.
So far I have the following in mind:
ASUS M3A78-EM AM2+/AM2 AMD 780G HDMI Micro ATX AMD Motherboard
$65
WD AAKS 640GB
$70
2*2GB DDR2 800
$45
AMD Athlon X2 4850e 2.5GHz Socket AM2 45W Dual-Core
$60
SILVERSTONE ST400 400W
$20
(See review: http://enthusiast.hardocp.com/arti [...] VzaWFzdA== )
Not bad at all for a $20 PSU. Better than the cr@ppy Rosewill, Logysis,etc.
Total so far: ~$262
What I need:
Case (some thing like a Shuttle case would be good)
TV Tuner (Need to be able to record HD)
Good CPU cooler that will fit in a HTPC/SFF case.
Any one got any better specs? CPU/Motherboard wise?
Message edited by Shadow703793 on 11-27-2008 at 05:51:01 PM
Sponsored Links
Look pretty good here are some cases the last one is a htpc case so it's doesn't have the shuttle look
http://www.newegg.com/Product/Prod [...] 6811146046
there are 3 different colors
http://www.newegg.com/Product/Prod [...] 6811112147
the silver version is 20 bucks more
Personaly I like the Lian Li case
Reply to col-p-todd
here is a good cpu cooler
http://www.newegg.com/Product/Prod [...] 6835118034
for the ram I would recommend corsair or OCZ
the psu might be loud since cheap psu usally are. But you just can't beat that price. You just might want to think if it is worth the extra cash for a quiter psu.
and for a tv card I would recommend getting a dual tuner for sure
http://www.newegg.com/Product/Prod [...] 6815116037
Reply to col-p-todd
Lian Li looks good. Is there any thing a little lower priced than that Zalman HSF?
With just the Lian Li case total comes to $400. Any cheaper HTPC case?
TV tuner looks good.
Also will CPU be a bottle neck?
How about this case?
http://www.newegg.com/Product/Prod [...] 6811163116
I'm looking for smiler cases like that. Any recommendations?
Also should I add a GPU like the 3450 with heatpipes?
Message edited by Shadow703793 on 11-27-2008 at 06:04:44 PM
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
The silverstone case looks good, no problems there. As for the GPU the onboard gpu will be good enough, only if your planning on playing games you might want to get an gpu, but if not just stick with the onboard gpu.
I don,t know any other good cpu cooler but you might just want to keep the stock cooler just have it run at a slower speed (this can be done in the bios) since the cpu doesn't generate alot of heat.
The cpu will not bottleneck for normal htpc use only if you'd wanna play games on it might it be a problem.
Reply to col-p-todd
If you would want a truly silent htpc you could do this by getting the lian li case and this cooler.
http://www.newegg.com/Product/Prod [...] 6835114038
since the case has a fan that will blow air over this cooler. then you just need to get a silent psu and your set.
This will cost a little more, but it's just an option you might want to consider:)
Reply to col-p-todd
Not a bad idea, since CPU is only 45W.
You could also step up to the new Athlon 5050e (45W) for a touch more CPU speed. For some reason, newegg doesn't carry it but ZZF still does.
Also, take a look at the Scythe Mini Ninja for the cooler. It's designed for low profile cases. The only downside is that the fan is 3-pin instead of PWM. Some motherboard's control the speed on 3-pin fans just fine, but some (like my Asus) don't. You can purchase a PWM fan if it's an issue.
Reply to rwpritchett
Checked out the review for the Scythe. It should do the work fine for a 45W CPU.
Here is the revised list:
$65
WD AAKS 640GB
$70
G.Skill 2*2GB DDR2 800
$45
$60
$20
SILVERSTONE Sugo SG01B-F Black Aluminum Case
$70
[Note: Might change case to a mid tower ATX]
Hauppauge WinTV-HVR-1600 ATSC/ClearQAM/NTSC TV Tuner PCI w/Remote 1178 PCI Interface
http://www.newegg.com/Product/Prod [...] 6815116007
$75
LG DVD RW With LightScribe
http://www.newegg.com/Product/Prod [...] 6827136153
$25
Will get the Scythe Mini if needed
Total: ~ $435
Tom's Hardware > Forum > Homebuilt Systems > New System Build > Help with HTPC build
There are 1116 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
