Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > ????A problem that can't be solve???? Desperately Need Help
Forum Graphic & Displays : Graphics Cards - ????A problem that can't be solve???? Desperately Need Help
:hello: This is the first time i post... so i dun know vry well..
my computer having a problem, where my gaming framerate suddenly drop from 160 fps and now can't get over 60 fps, in counter-strike source video stress and playing need for speed carbon my computer got stuck like hell when speeding(nothing change,on low or high setting).... i'm using a XFX 8600gt , Phenom X4 9600 , 4gb corsair ram , 500wat pwr spply...
at 1st i try to change the os(Vista ultimate to xp) and format the system , nothing change... changing the driver also won't solve the problem... i warranty the graphic card.... swap a new one, nothing change.....
any tips or comment will be greatly helpfull..... i
Sponsored Links
maybe go post somewhere where they are idiots and believe this crap .......
Reply to bf2142-rules-ok
have you got vertical sync enabled?
Reply to montyuk
lol at reformatting and downgrading to xp and getting a new card.
Running at 60 fps isnt exactly "broken"
Yeh VSYNC usually limits the fps to around 60. Had that problem in cs 1.6. Disable it.
TBH the only time iv even considered wanting to go above 60fps is in cs 1.6 for SURF MAPS looool
Its not really a problem
Reply to tomdrum
no....i already check the vsync setting... it's off setting.... even on the forceware desktop setting i off the vsync...
even on need for speed carbon...... high and low setting don't make any different.. vsync is off....
Reply to Zerox_strike
Plz help..... i've been searching for the solution for almost 1 years..
my own analysis so far.. tat game image quality does'nt make difference no matter i on or off the vsync, it still stuck like i was using old graphic card...
i've alrdy swap a new one, but a same model..... still dun change..
@OP: What is your exact PSU? Also what are the GPU/CPU temps?
Message edited by Shadow703793 on 12-21-2008 at 05:46:07 PM
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
load up gpu-z from techpowerup.com
select the sensors tab and tick the box so that it runs in the background.
now run your game, watch for the decrease in speed, exit said game
and look at the sensor readings, what changed when it happened?
Reply to montyuk
ffs wats the problem??? 60fps is great.
Reply to V3NOM
iON+ 500 watt...... the temps are normal.....cpu like 39c and Gpu 54c
if almost all game run on 60 fps... i think it's normal, but when playing need for speed carbon... on low setting, it will stuck like hell when speeding...
right now i'm playing fallout 3, the game have a big maps like crysis.. and the framerate like 5 or 10 fps .... even my friend computer using 1650xt ati... run at 20fps above....
if vsync is on it locks it to 60fps doesnt it?
Reply to V3NOM
no....the vsync alrdy off mode.... even on the driver setting...
em... i can't see any diference.... the core clock and memory seem dun bugde an inch...
are the clocks what they are rated for on factory specs?
Reply to V3NOM
:O could also be temps... whats the gpu temp while running a game/stress test
Reply to V3NOM
yup....the clock was factory spec.... i don't overclock it... the temps was 53 when idle, and 57 when load..
What map do you get 60 fps de_dust 2 cause i get 70 with 8800gt 4200 amd 2 gid drr so yours does not soun right i think you have a proplem unlike the outher duds who say its great . did you change resoulution.
Reply to buthead09
If you get 70 with a 8800gt and he gets 60 with a 8600, sounds like the 8600 is doing quite well
------------------------------ I went drifting, thru the capitols of tin, where men cant walk and cant freely talk, and sons turn their fathers in
Reply to jaydeejohn
i'm doing a video stress..... it's like a benchmark... and i have test that playing with 20 bots on every maps and the fps like 15-29... the resolution was only 1024x768..
There are 1170 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
  • 01:00 xpax won the Freshman badge
  • 01:00 Mizoguchi won the Freshman badge
