I intend on leaving my computer overclocked to 3.33 ghz. I've got a baseclock set at 166 and the dram frequency at 1333. Everything else is set at Auto in my ASUS p6x58d bios.
My ram is DDR3 6 GB (3 x 2 gb) Corsair Dominator TR33X6G1600C8D which is rated at 1600 mhz at 8-8-8-24. Current speed is 1333 mhz.
Shot at 2010-04-04
Shot at 2010-04-04
Shot at 2010-04-04
The current timings at 663 mhz is 8-9-9-24.
My questions are:
1) What is the optimum DRAM speed (1333, 1600, etc) should I be running this ram at, if I want to maintain the 3.33 ghz CPU speed?
2) Can I set the Asus Bios Ai Overclock Tuner setting to XMP, then set the baseclock frequency to 166, then set the dram frequency to 1666?
3) Should I manually enter in the timings?
Shot at 2010-04-04
Shot at 2010-04-04
Shot at 2010-04-04
My questions are:
