Guys,
I added a second video card today to a existing system. It posts and boots in to windows. I see the progress bar then where the login would be its blank. blank screen. The specs are below with details
xfx 780i
Pc power and cooling 750w silencer
Windows 64x
2 xfx 9800 gtx+
Qx6850 intel
velociraptor 300gb
Crucial 2 balistics pc2-8500 (i know i know) no negitive comments just help thanks
my bios has a date of 9/9/2008. I got the update via xfx support webpage.
If i remove the bridge and the card its boots to windows and operates fine. I have not been able to enter windows with both cards in at the same time. So i have not had the chance to enable SLI. anyone deal with the same issue?
*I've posted this in other areas (Grapics and display ) with no reply. I can boot up in to safe mode and use windows normaly with both card and i go to device manager and i can see both cards there. idk what the issue is i'm running out of ideas. i also just removed the display drivers and reinstalled the most recent ones from nvidea.com... ANYONE?
xfx 780i
Windows 64x
2 xfx 9800 gtx+
Qx6850 intel
velociraptor 300gb
