Help me build a ~650 PC please
alishaikh
I have been searching around a few days and came up with a good PC for ~850 http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=5497649, but my parents just told me I have t limit to something near 600-650, I already have Vista Ultimate 64 and a Monitor, but I don't know what parts to get for a good cheap, and long lasting P.C that plays the latest games(Far Cry2,GTA IV,Crysis, etc) and will continue to do so. So my question is"Please build me a P.C for around 650". Sorry If I'm asking too much
11
answers
Last reply
More about help build please
Ok, your not asking to much
Everything is www.newegg.com prices
CPU and MOBO: Asus P45 and cpu E7300=$196
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.138372
Video card 4850 ati: only $129
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102770
CPU cooler:XIGMATEK HDT-S1283 120mm=$21
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003
Memory Ram:CORSAIR 4GB (2 x 2GB) 240-Pin=$19.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145184
Hard Drive:HITACHI Deskstar 500Gb=$54
http://www.newegg.com/Product/Product.aspx?Item=N82E16822145215
Case:Antec 900=$56
DVD Burner: lg light scribe burner 22x =$24
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136153
Power Supply: Thermaltake Purepower W0100RU 500W = $14
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153052&cm_sp=DailyDeal-_-17-153-052-_-Product
Grand total only $513
However I would recommend to leave everything the same and change the 4850 video card for the GTX 260 core 216 (keep the P45 motherboard). If you do this Grand Total is= $623
Hope this helps -
In that case the E7300 I recommended is going to bottleneck the GTX 260 core 216. Unless you overclock it, do you plan on overclocking. If not, maybe you should get the E8400 cpu and the gtx 260 (not core 216) or the 4850. Either way on a 17in you should be able to max out aa and settings in all games except crysis, in crysis you will probably be able to use cheap very high max resolutions but no aa.
Hope this helps -
In that case it is your call. You should be able to get the E7300 to a least 3.8 if not 4.0GHz, which should keep up with the gtx 260 core 216. This is what I recommend you should get a good system, and if you overclock you should be able to play every game on max settings with aa on you 17in monitor.
Or if you want the slightly stronger E8400 and the gtx 260 (not 216 core), you can do that as well.
I recommend the the above, but it is your judgment call. Either way you are going to get a very fast computer that can play all the latest games.
The only thing is that you will not be able to sli the gtx 260 without changing the motherboard to the 780i which is out of you budget, but it does not matter at you screen resolution because you will get very little gains from that.
Let me know what you decide,
Hope all this helps -
Paul seems to have written an article just for you ($625 gaming machine):
http://www.tomshardware.com/reviews/cpu-graphics-overclocking,2082.html
Related Resources
Build
Windows Vista
Systems
Product
Related Resources
- First build (help please)
- $2000 i7 Build - Help!
- Core i7 build advice please
- A girls first build need some help!!!
- I7 920 build
- My New Build; Reviews/Suggestions please
- Please advise, first build! <$550
- I want to build and would like some help.
- $800 i5 build
- Help Finalizing Core i7 $1800 Build
- All AMD Build
- New build
- Complete Final Build...Let Me Know How I Did
- Please review - proposed first build
- Core i7 build, help me out here
