Malware removed ...Svchost.exe problem
First off Would like to thank " Simple and free guide to removing malware " By aford10 Real helpful on the removal of my malware /viruses ... Computer is running almost perfect .. Except one Problem one my processes of Svchost.exe is using between 200k to 275k of mem usage runing comp up to Cpu 75 to 100% depending on what i am doing on comp. did only use between 12k to 25k mem usage any help would be great XP Home Sp3 what can i do to fix this problem ?
1 answer Last reply
More about malware removed svchost problem
  1. Not sure how to fix it, but if you use process explorer and hover your mouse over the svchost process(es), it will show you which services are running under that instance of svchost. You may be able to track down the problem from there.
Configuration Malware Svchost.Exe Windows XP
