Archived from groups: comp.sys.palmtops (More info?)
Most all Palms, current at least, are 5 volts DC tip positive
"Me_Again" <sturgesk@nospam.st.net.au> wrote in message
news:42a673f0$1@dnews.tpgi.com.au...
> I purchased a Tungsten W from an ebay seller, and when it arrived, the
power
> adapter was missing (as advertised).
> I am charging the device via a USB cable, but have a cradle, which
requires
> the power adapter to charge the W.
> Can anyone tell me the output voltage of the afore mentioned power
adapter?
> Thanks in advance.
> Kevin
On Wed, 8 Jun 2005 14:34:04 +1000, "Me_Again"
<sturgesk@nospam.st.net.au> wrote:
>I purchased a Tungsten W from an ebay seller, and when it arrived, the power
>I am charging the device via a USB cable, but have a cradle, which requires
>Can anyone tell me the output voltage of the afore mentioned power adapter?
>Thanks in advance.
>Kevin
The cradle for my Tungsten C has the voltage and polarity molded into
the plastic on the cradle right next to the power adapter socket. For
the T|C it is 5 volts, center positive. It should be the same for the
T|W but why not look on the cradle.
Vic Roberts
Replace xxx with vdr in e-mail address.
On Wed, 8 Jun 2005 14:34:04 +1000, "Me_Again" <sturgesk@nospam.st.net.au> wrote:
5.0VDC, 1.0A regulated. Moto part # 180-0711 model R410510.
John Bartley K7AAY USBC/DO PDX OR USA
"This is a carburetor," Hank tells his son. "Take it apart, put it back together; repeat until you're normal." - KOTH
