I have been getting many different answers and suggestions of the best card for my machine. You guys know much more than I do about graphics cards and other computer parts. I am sorry but I had to post a new thread to get a better answer. Some say I could run a Radeon HD 4670 512MB 128-bit GDDR3 some say I cannot. I rather not take the risk of burning out my whole computer. Now I am just asking what card will work best with my machine without buying other big parts like new a power supply because I do not know any who can install that for me and I rather not go through that trouble. I would buy a PCI-E Power Supply Converter cable though, if needed. I was thinking of getting the XFX PVT84JYAJG GeForce 8600 GT 512MB 128-bit GDDR2 PCI Express x16 SLI Supported Video Card (it requires 300 watt power supply) but I am sure there are some better ones I can get. I do not want to spend more than 150 dollars. I do not care if I get a Nvidia or a ATI. Just need a card that will the best for me.
The main game I play is World of Warcraft. I do not play or high graphics and I do not play on really low graphics. I play with a resolution of 1280x1024, mid-range terrain distance, spell detail medium, I have the terrain lighting checked. I do not have the full screen glow effect, I left the multi-sampling on the default, the anisotropic filter on the lowest, shadow quality on the lowest, all the environmental details,radius, distance on the lowest, no death effect, and no vertical sync. I get around 32-70 FPS depending where I am of course and what I am doing. In the the new zones "Northrend" I get around 26-50 FPS questing.
This is with a 1G of RAM. Plan to get another stick of 2G of RAM. So, please take that into consideration while giving me the best card suggestion for which card will best suite me for World of Warcraft high quality and performance.
My computer specifications: 3.00 GHZ Pentium 4
19" Monitor with a native resolution of 1280x1024
1G of DDR2 RAM (Will buy a 2G stick of RAM making it 3G or RAM)
I have a 256MB PCI Express™x16 (DVI/VGA/TV-out) ATI Radeon X600 SE
(It is the same card that came with the computer, need an upgrade badly).
I have a Dell Dimension E510
Only have a 305 Watt Power Supply.
Message edited by Shpati on 12-23-2008 at 01:12:54 AM
Yes, a 4670 would be much better than an 8600. I'd recommend that as well. Anything much more powerful, like the 4830, even if you switched out your power supply would run into CPU limitations with such an old processor.
------------------------------Phenom 8750, ASUS M3A78T
4 gigs Kingston DDR2 800 two 1T SAMSUNG HD103UI
Sapphire 4870x2, Sony BDU-X10S BD-ROM
Antec Neo 650 PSU Antec Nine Hundred, Acer H213H 1080p LCD
Reply to yipsl
