Power supplies
  • Power Supplies
  • Computer
  • Components
  • Product
Last response: in Components
February 22, 2009 5:01:58 AM
Hi i am building my first computer and i have got the 780i mobo i plan to run sli and i was wondering what kind of power supply i will need to run my components
More about : power supplies
a b ) Power supply
February 22, 2009 5:56:39 AM
What are the rest of your specs?
February 22, 2009 10:16:42 AM
Aren't we supposed to have a seance and divine that information?
February 22, 2009 10:30:12 AM
xfx 9800gtx two for sli, intel c2q q6700 2.66ghz cpu, OCZ SLI 8096MB PC6400 DDR2 ram, Creative Labs SB X-FI Titanium Fatal1ty Sound Card, Seagate Barracuda 7200.11 1TB Hard Drive Bundle With Windows Vista Ultimate 64-bit DSP OEM DVD, This is what i have got so far. I need a good cd/dvd burner and a power supply but i dont know whats good in this department. Also my pc case can run 6 fans if i want it to.
February 22, 2009 2:50:19 PM
will the 750wat be enough power if later on i want to convert to 3-way sli
a b ) Power supply
February 22, 2009 3:05:19 PM
No, you'd probably want 1000W, so Corsair HX1000.
February 22, 2009 3:10:35 PM
1000watt for 3 9800s?!? u kidding...i mean its nice to have a big PSU but its not necessary
750 would do fine
February 22, 2009 4:46:51 PM
You might have wanted to include that in the OP as well.
Yes it will power 9800GTX 3x SLI, but you will need two Molex to PCIe adapters, which sometimes come with the card.
February 22, 2009 10:39:41 PM
Explain the Molex to PCIe adapters. I'm not sure what that is.
February 22, 2009 10:50:57 PM
Its an adapter that changes 4 pin molex connectors (for fans, controllers and such) to a 6 pin PCIE connector for GPUs.
Ull need them cause the 750 only has 4 connectors for PCIE and the 3 way SLI will need 6, so ud just need to convert them
February 22, 2009 11:28:19 PM
That 750w will be more than enough for 3 9800 GTXs, believe me I owned one.
Edit: The red is also sexy!
February 23, 2009 5:09:52 AM
And more importantly these days, less expensive. ;)
February 23, 2009 8:20:35 PM
thanks guys for the help and advice i ordered the PC Power & Cooling S75CF 750W
February 24, 2009 2:21:19 AM
Wise choice
February 25, 2009 8:42:25 PM
I was looking at the xfx 9800 video card. Out from the memory it has ddr3. Do I have to run DDR3 on my motherboard before the card will work? I was getting the 780i, so can I put the ddr3 on the 780i motherboard? Also, can I run 8megs of DDR2 on the 780i with the xfx9800 video card in tri-sli?
a b ) Power supply
February 25, 2009 9:03:14 PM
The video card RAM (which is actually GDDR3) is in no way related to the system RAM. 790i uses DDR3, 780i doesn't. It's not worth the extra money.
February 25, 2009 11:13:18 PM
Thanks for the response.
